• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
You could also make the joint off behind the new larger skirting board
Correct, but don't like it Seems a bit Cowboyish to me, but I'm old School so take no notice.
Any idea why the blender has tripped my downstairs breaker? Annoyingly when the extension was built they took the lounge feed and extended it round the kitchen but never bought it back to the CU (Concrete floors maybe put them off) So when the CU was upgraded this year a different sparks could only throw in a 16amp fuse as opposed to a 32amp. Could it simply just be a matter of to much on the circuit when the blender is running with it's 1560w motor?
Oh dear that is a bad news your kitchen needs a ring main 32A preferably on it own circuit suggest you get a proper sparks in to see how little damage he can do to rectify this
whats tripping when you turn the blender on the mcb or an rcd
Yup there part p registered,
Rubbish. If they are claiming that they are liars. There is no such thing as part P registered. Part P is a building regulation not a qualification. Try asking for their registration certificate to call their bluff.
  • Disagree
Reactions: UNG and James
If somebody is on a register of competent part p electricians then aren’t they part p registered?
Reactions: James
Well i'm confused. :)
@ sparkyAndGeorge - (Great name by the way! - It's the MCB at the CU that governs my downstairs sockets (16amper apparantly as the ring was never extended back to the CU.
Perhaps you could tell us what advice you need now? The socket would be easy enough to reposition, the lights needs further investigation by somebody on site we can only speculate from here. Does the blender trip the mcb on another circuit or just that one?
I havn't checked it to be honest. I'll give it a go on another circuit and find out. Can the lighting faults be isolated via testing aparatus? I take it most sparks would have the tools to do this in the van. Trying to understand the process of how one narrows down where it occurs so i know what to expect in terms of work and time for any further spend. If the problem is existing and has been amplified by the addition of my new switches and sockets then i'm assuming this troubleshooting would be deemed additional works for quoting? What do you think?
I’m an approved part p electrician and and also registered as such..
As I keep saying part P is a building regulation not a qualification.
Perhaps you would show us a copy of this qualification that you claim to have!
All electrical work must be carried out in accordance to part P of the building regulations. But there is no part P qualification as such.
I am part p registered not qualified..
I suggest you get your terminology right before you start calling people liars..
What is it you mean?
Part P Qualified or registered??
I am not claiming to be part p qualified, I said I am part p approved/registered..
Please read and understand what I have written before you twist it into something else
Reactions: Pete999 and Spoon
Not all electrical works !
The point he is trying to make is that you are registered with a CPS (competent person scheme) to satisfy the requirements of approved document P of the building regulations.
His point was that anybody claiming to be part p approved/registered is a liar.
I am on a government register of approved part p electricians.
Reactions: James
Beefy
Surrey
Business Name
qa
Advice on faults and Ideas for fixes
Electrician Jobs
Electricians Jobs
Beefy,
Beefy,
