Donkey_uk
HI Can anyone please advise me on the correct rcd and cable for power to my shed
I would like to run a power lead from the consumer unit to my shed , my unit has RCBOs, should I use a 16am RCD A / B or RCBO from the main board? This will then go to my shed into a 2 switch consumer (shed unit) also what size cable should I use. I know I should use SWA but I would run this above ground and along a wall and I will also put this inside cable trunking, so would normal 6mm twin & Earth cable be ok?
I will be running the following in my shed
Freezer
Tumble dryer
2 Sockets
2 outside light and 1 inside
I would like to run a power lead from the consumer unit to my shed , my unit has RCBOs, should I use a 16am RCD or RCBO from the main board? This will then go to my shed into a 2 switch consumer (shed unit) also what size cable should I use. I know I should use SWA but I would run this above ground and along a wall and I will also put this inside cable trunking, so would normal 6mm twin & Earth cable be ok?
advise a spark in part p job.
Adding a new circuit to the CU in notifiable work in England & Wales under Part P of the building regulations.
While you can get the paperwork done via the council, they will charge you far more than an electrician who is already a member of one of the "competant person" schemes such as NICEIC (or SELECT in Scotland).
Reactions: buzzlightyear
So is this something i can do? only a spark can do this and i need to get building control involved
one question are you insured for this type of work and what qualifications are there .
It is something you should not be doing. It should be regestered with your local building control.
Simplest option is to find a registered electrician and discuss what you want.
You can save money by doing the donkey work of installing the cable, but you have to have all of that agreed in advance as the electrician is the one signing off the work and they need to know the right cable was used and installed in a suitable manner. Their --- is on the line if it goes wrong.
Ok thank you guys, I will leave it be lol
I take it I can run sn extension lead to the shed is that correct ?
Typically a tumble dryer uses quite a lot of current, I would be very sceptical of having that along with a freezer, etc, on an extension lead. If it goes you loose the food!
Your original idea, a dedicated circuit, is best by far but you really ought to be sizing it for at least 20A if feeding that lot.
If the freezer has valuable amounts of food in it you might want to consider having it on a dedicated circuit, or arranging some sort of alarm in the event of power loss.
Reactions: stevethesparks
I love ice cream flouting out of a defrosted freezer and so do dogs .lol.
  • Funny
Reactions: pc1966
If you have to use an "extension lead" arrangement to avoid the Part P restrictions and cost, then please at least use outdoor rated cable to make one up, such as H07RN-F like this:
That is probably OK to around 30-40m on voltage drop, otherwise you would need to look at 2.5mm even for a 13A extension.
You still need to clip it away from any mechanical dangers, and it is not suitable for burial in the ground, but it is easy to work with and fairly cheap (sold by the metre in many places). At the shed it can be terminated in a 4-way 13A socket block and you can plug things in there, also any lights on a plug with 3A fuse.
Of course it has to be from a RCD-protected socket, but you mentioned an RCBO board so I guess that is already in place.
Power to Shed
Donkey_uk,
pc1966,
