Discuss Hot tub problem in the UK Electrical Forum area at ElectriciansForums.net
Hi guys my hot tub has been fine for the past year but now when the heater turns on it trips my guess is a faulty heater if this is not the case do you have any ideas what it is most likely to be ? Thanks
What does it actually trip, the RCD or breaker.
Could be a faulty heater or water ingress into the connections.
is it a MCB or a RCBO? very unlikely to trip a MCB unless you have a short.
Reply to Hot tub problem in the UK Electrical Forum area at ElectriciansForums.net
Replaced our old 240v hot tub with a new one, which also uses 240v for motors, heater, etc, and 120v for low amp LEDs and touch screen control...
Hi All, My triton martinique shower suddenly became only lukewarm, i get my trusty multimeter out and sure enough, one of the heater coils has...
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
Hello, The CUR6330a keeps tripping, even when no sockets are turned on. The issue is the "sockets" switch though - it's the "sockets" switch that...
