Periodic inspection, the last date was 2000, so well overdue.
I just moved in this house in march as we bought it, thats the reason we wanted to switch for a smart meter for the gas instead of the already prepaid meter installed
Thanks for your advice i guess its good time to get it all checked
It shouldn't be related to the meter install
I haven't heard of this RCD tripping related to the new meters , although nothing would ever surprise me now
I have come across this exact problem. All the tests came back fine, there was no indication of a fault on any of the circuits
Same brand RCD, old memera one. Have read online of others having the same problem, again same memera RCD. Basically the smart meter is interfering with the RCD, causing it to trip randomly.
In my client's case, the smart meter was immediately below the fuse board. (don't laugh!) I took a piece of cardboard, wrapped tinfoil around it, and placed it between the meter and fuseboard. It hasn't tripped since, I kid you not! Obviously, if you intend to do this, make absolutely sure that there are no exposed live parts that could make contact with the foil, or you'll be fried alive.
Lol
Nothing should ever surprise you when dealing with electrics
Call your supplier and mention that its happened since the visit from the Engineer. He may have left a loose connection or reverse polarity (both of which can be dangerous). They may send someone out to check on the meter. Or if the problem persists, may pay for a sparky to check the properties circuits.
Hi everyone
I called an electrician twice , he charged me crazy money ?? however because of the tripping or during the installation he told me my electric shower has became a hazard, need to change it as it showing some fault in his reader...
He became crazy as he couldnt find any fault, and then asked me what time the tripping happen, and other questions, he came to the exact conclusion of pretty mouth that the unit memera one in the past for one of his client use to trip just after the installation of a smart meter
As pretty mouth said its exactly whats happening for me, as i mentionnet in my first post, eon came to replace the gas meter ( as i already had a smart electric and never had any issue) but decided he will need to put a new electric meter and synch both of them, the problem now is everytime.eon send a signal to the electric meter as it uses radio signal, which i guess are so strong it trip my rcd memera one
I haven read about your tricj regardent the foil but i am afraid of that as i have 2 kids at home
Can anybody advise me please? I already paid more than 200£ for the search of the problem.and now i have an electric shower to replace ????
I am going nuts and really dont know what to do
Could i call eon to come back and replace the meter ?? Or any other thing?
Thanks again for all readers and replies
Hi everyone
Does the shower still work? Sounds like he's damaged the electric shower whilst carrying out insulation resistance tests? But would only really happen if it was one with electronics in.... who knows...
Just try the tinfoil wrapped cardboard trick first, the tinfoil isn't connecting to any electrics so no risk to yourself and kids.
Can you or somebody advise in the picture where should i put it? Thanks
I would tape it to the underside of your consumer unit (fusebox):
Thanks for your reply
Right i will try that and make sure to call to send an engineer to repace or put back the old one
Already because of the trip last night had to throw food from fridge and freezer having 2 kids at home it was such a bad situation this morning...
I’m sorry to hear this has turned into a right saga.
I’d hold fire on the shower change - as above does it work?
Hopefully the card and foil shield will solve the problem short term.
(I’m wondering if there any forum members on east side of Manchester? )
Reactions: Pretty Mouth
Seems a stretch doesn't it, the meter tripping the rcd ?
Anythings possible I guess
I hope this works for you, and please do update us with how things work out. I'm interested to hear if your supplier will take any responsibility for the problem.
The electric shower works but the electrician told me it has become a hazard, with some equipment he showed me that its showing somr fault on the reader ( by putting 2 wires on 2 electric point inside the shower) so he told me hes cutting it off and has put tape on wires and asked me to replace
Not only that the constant tripping has blown 4 bulbs in the house and my front flood light, i had to replace them all which cost me aswell today, i really do believe something bad happened during the meter installation but wont accuse the engineer as i have no proof
Regarding the foil trick i have put it under the unit as advised, fingercross no trip happens now , i will call eon in the morning to send out an engineer or to give me back my old meter
Will keep updating as it can help someone in the future
I presuy the electrician is saying there's a low IR reading on the shower heater tank
When they go the reading is usually low enough to trip the RCD ime, maybe it's higher than that
RCDs are unpredictable at the best of times and I've seen some strange things happen, so definitely wouldn't be amazed if this was caused by the meter
It would seem that some rcd’s mounted close to some smart meters can in some circumstances cause the rcd to trip.
presumabley when they are transmitting data back to base.
when you think about it, an rcd is infact basically 2 coils of wire, wrapped round the conductors.
the rcd compres the current flow by measuring the current in the coils of wire.
strong radio waves could upset the balance.
it is not the first time we have heard this type of thing happen and although it seems far fetched, I believe it is a genuine problem for some people.
it is also something the suppliers are unlikley to spend much time investigating or admitting to.
Seen a fluorescent on a non RCD protected way tripping an RCD
The capacitor apparently was causing it
Definitely unpredictable devices
The smart meter uses the mobile network to contact the supplier for monitoring etc, in poor reception areas this software jacks up the transmit power to try and get a better signal, this in turn can have a negative effect on RCDs.
One option is for the supplier to fit an external antenna which should sort this out.
Reactions: Jim_e_Jib and James
Rcd tripping with no switch on after smart meter installarion
Desikeera,
Simon47,
