- Jul 15, 2016
- 23,299
- 1
- 29,151
- 315,788
- United Kingdom
- Electrical Engineer (Qualified)
Using 63A mcbs is a bad idea as others have said you will not achieve selectivity. Any fault in a dwelling may well disconnect at the main board you need to insist on a Ryfield.
