May be he's switched jobs because this one didn't turn on for him or has he moved on from light duties to power away from this thread:teeth_smile::teeth_smile:
Broken tester, the Common link brown of 3-core belled out fine with my tester.. But when i put pressure on anything with the probes it belled out fine.. I pressed one down on a wall and the other on my arm and it said it was a circuit
SO the issue wasnt as simple as all put out to be, cable belled out fine BUT due to testers being broken wasnt fine therefore that was the issue
Sorry for late reply been busy
Hum....
With 3 or 4 other sparkies on hand didn't you try another tester? to see what readings they got.
Not convinced, sorry mate
Reactions: 3 people
Not convinced either, load of rubbish in my opinion,
first year apprentice could have come up with a better lie.
Reactions: 2 people
Its a brand spanking new fluke one
So there was no real thought going through our heads that it was going to be anything to do with the testers
Fluke T120 Voltage & Continuity Tester Brand New
But surely if it was all connected correctly as you insisted, it would therefore be totally irrelevant wether the tester was working or not?? I'm more confused now than ever !! Lol
I hate bullying axel and hope you don't think I'm jumping on the band wagon fella, but 100% agree with will here, it really is school boy stuff, basically the fact 4 sparks looked at this seems ridiculous, I'm almost at a loss to be honest here, 2 way switching is very very simple and a meter wouldn't be needed IMO to solve this problem, I am not trying to bully you at all but come on lets have the truth here, please just tell us what really happened.
well I hope none of the sparks who looked at this with you ever apply for a job at MDJ, god help us, fair enough then, if you say so fella.
Bottom line is how long would it have taken to remove the line and switched line, replace them with 2 short tails and set your tester to R2 and check the continuity/switches out? - me thinks no more than 15 minutes
Belling out is no replacement for checking the R2 values - especially as you could check the switches and the cable with the same test.
The only thing i can say was it was at 4:30pm when it was found and we leave at 4:00 and Dont get paid overtime.. So was all ready to leave anyway.
But like say wired so many of these, done much larger scale ones etc and never had a single issue so was bizarre to suddenly come across this with broken test leads.
You would be lucky to get someone like me ;) HA >.>
As I mentioned I won't tolorate any bullying myself and therefore after your explanation whether I believe it or not now bow out of the thread, I still think it is ridiculous 4 sparks couldn't sort it out but won't mock you, all the very best axel, chin up.
I'm confused how broken test leads were closed circuit, if lead damaged wouldn't it work correctly or be open circuit?? I can't see how it's possible for the damaged leads to show continuity, or have I missed something..... At least the thread title is 100% correct..one to confuse you all!! Lol
Don't take any notice of these reprobates. They are still in Friday evening mode.......
Well done ! I had the same problem myself in the middle of an assessment. Just as well I had a spare set of leads... hint, hint and sloved the problem pdq without embarrassment I ripped them apart to find the earth lead had become disconnected.
I now have two sets of leads.....
One to confuse you all!!
axel132132,
ackbarthestar,
