Search the forum,
Discuss Water bonding query in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Doing an EICR on a commercial install, there’s a copper pipe comes down a pipe chase with the stop cock fitted onto it, it’s then pvc pipes that come out the other side and these are fitted onto the sink, does it require to be bonded??
Depends if it an extraneous conductive part, measure ir from pipe to met, I use 23K ohms as allowing 10 ma of fault current to flow.
GN8 gives more information about this and other values that you could use.
I understand your question and it can be a can of worms, on the one hand as mentioned in your previous reply is it a extraneous conductive part, that said a photo would be nice, if it were my house and the pipe a decent length I would probably bond it, lets see a photo of it, purely to keep us amused on this Friday night
Reply to Water bonding query in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Greetings, I am homeowner and looking to confirm if I will need earth boding to water pipes. There is already earth boding near Gas meter and the...
No waffling, going to get straight to the point. Main water on the exterior of the building in plastic. Changes to copper inside the building...
Not sure on this one. Mains water is coming up from the ground in lead pipe in bathroom. 2 inches of copper pipe before the stop tap. All...
Hello, Carrying out remedial work on a commercial site and I've come across a metal out building that has a water supply to it. The water pipe...
Hi, I'm having a new boiler fitted in a new location. I need to provide power for the boiler which I'm looking to do myself. Boiler: Ideal Logic...
