Discuss 2357 Portfolio Question I dont understand in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
kris jones
Mentor
Hi All,
Im trying to answer this requirement for my portfolio:
'Show me evidence of procedures that are in accordance with requirements for electrical systems and equipment for relevant sections of the building regs'
(criteria section 312.1.2)
Now it may be me but Im struggling to answer this as I think its worded badly and I cant see past that.
Can anyone elaborate?
i'd assume that what is required is some pictures of work you've done that complies with building regs. e.g. sockets and switches mounted between 450mm and 1200mm; CU mounted between 1400mm and 1500mm;
Because it says relevant sections of the building regulations I might assume it wants you to specify which sections.
So if you have sealed a cable penetration to prevent fire spread this would be part B.
If you a sealed fitting to prevent moisture ingress part C.
A fan with the appropriate extract rates for the specific room part F
And possibly good workmanship regulation and approved document 7 and Part P.
But yes that is an abysmally written question.
Reply to 2357 Portfolio Question I dont understand in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi, Currently working my way through my NVQ portfolio (Nearing Completion) but getting stuck on how to complete the following criteria due to...
A bit of a mini essay but these questions have been building up in my mind over the last weeks and months as I've been studying and volunteering...
Hello, I am about to embark on completing the C&G 2365 level 3 diploma, but I was curious about the portfolio evidence gathering required at...
Hi everyone I'm seriously struggling with interpreting the nvq 3 portfolio criteria. In unit 315 it says I need to install 4 types of wiring (5...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
