Search the forum,
Discuss 50mm duct & hockey stick - new supply in the UK Electrical Forum area at ElectriciansForums.net
Laying ducting and hockey stick as preparation for new 3-phase supply which will be installed after front drive is done.
How is the hockey stick joined to the duct?
I was told by Polypipe technical that that end of the duct slides into flared end of the hockey stick and forms a tight joint. But they lied. So now I have a butt-joint to deal with. Shall I wrap the join in duck tape? Using Polypipe 50mm duct (60mm external diameter) and Polypipe 54mm hockey stick.
Thx
54mm seems bit on small side for 3phase, is that what was specified?
The documentation from SSEN specified size of ducting (min 50mm), but silent on spec for hockey stick. A meter box / hockey stick supplier said 38mm hockey stick will be fine but I went larger anyway. BUT just need to understand how to join duct to hockey stick as the SSEN spec is silent on that too.
Every duct i have used was always a slip joint. A butt joint will be an absolute nightmare, soften the plastic with a heat gun and push it into it or buy the correct joint.
For the likes of the "BT" 96mm duct you can get sleeves to join male-male pipes, for example using an off-cut that lacks the female flared end. However, unlike the flared joint they are not tight fitting so a bit of PVC 'glue' (the sort used for PVC waste pipes) can help keep it in place.
Starting from where you are, I'd get a slip coupling for the duct, and build the end of the hockey stick up with duct tape to fit the coupler.
As long as it stays together while you backfill, it'll be fine and no one will be any the wiser.
Are you putting in a draw cord?
Reply to 50mm duct & hockey stick - new supply in the UK Electrical Forum area at ElectriciansForums.net
I've been looking in to upgrading the mains supply to a large house that has since been split into 4 flats and add a new ryefield board etc. UK...
E
I think I've Posted this before, but I've just updated it. Some of the sparks where I work still get a little confused of what the different areas...
78K
