T
tuanduong
Hi all, it is some time since I visited this site,
but here I am looking for some guidance.
When I last worked seriously on electronics
they were all glass valves, so I know nothing.
I tried to convert a LED work light to infra-red
by removing the bright white lights and fitting
IR lights at 850 nm, there are 24 lamps, powered
by 3 X AAA batteries, when I switched on nothing
happened except the resistor got very hot.
I may have been sloppy in my soldering and left a
short circuit somewhere on the board, though I
like to think that I didn't, if not that can you tell
me why the circuit didn't work, I assume that the
different colours of LED have different electrical
values, but I have no idea what they may be.
There was a small calculation where I had to know
the voltage supply + the voltage of the lamps time
a large number that I can't remember, nor can I find
it again on the internet.
Any advice and guidance will be accepted with a lot
of gratitude.
Thank you in advance.
Mike.
of gratitude.
Mike.
