G
GBDamo
Looks very professional when used for switch drops but...
And I am braced for impact.. :eek:
How do you know which is feed and return?
Installed a 12 gang grid switch and used Brown/Brown and when wiring up the switches was wondering if there is a trick to knowing which is which.
Was a bit of a faff but sorted it during dead testing today but thought, why isn't one core distinctively marked, or maybe a different colour, say blue?
just remember that the left hand brown is always the feed, easy when you know how!! ;)
p.s. just in case, please don't take this too seriously guys and girls.:D
Do you need to know?
Generally this cable is used for the drop to a single switch, or one switch on a multi gang switch, so as long as one is in the common terminal and the other in L1 it will work. There is nothing requiring the feed to be in common or switched live in L1 (if there was then 2 ways wouldn't work very well)
Other than half the switches being on/down and half on/up.
Don't know about anyone else I would simple sleeve the brown with brown for the SL. Nice and clear ;) or you could be boring and just label tag the SL. :cool:
Used all the time here. I'm fact its very unusual to use brown/blue for a switch here. Sometimes one shade of brown is darker than the other. If not, takes 2 mins to bell it out. I don't really understand why it isn't used across the water to be honest it is the correct colour rather than having to sleeve blue leading to lazy people not doing so.
Completely agree. It should be mandatory. No-one here would dream of using brown & blue for a switch drop.
