Discuss Canister lights from 1985, bulbs burn out WAY too early in the Lighting Forum area at ElectriciansForums.net
I have some canister lights in our bathrooms where incandescent, CFL, and LED all burn out too quick. We used to have the problem with canisters in our living room but had them replaced many years ago and they seem good now. So I was thinking I might need to replace the canisters in the bathrooms also. Before I go to the trouble of replacing them, I wanted to get some opinions. Does it make sense to have bad canisters? What is even in there that can go bad and cause bulbs to burn out?
Harry incandescent bulbs have a Filament in them and when they get a little age on them they will burn out quick. Not sure what a CFL is but older light fixtures usually don’t mix with LED bulbs. Canister lights has a small ballast in them. How many light fixtures do you have to be replaced ? If it was me I would just replace them.
if the canister lights have a closed back design ?
Then the lamps will run much hotter,
At when compared to an open back design
So my guess is these new lights are a closed back design with little or no ventilation
so your lamps run much hotter and suffer from short life span.
poor contacts between holder contacts and bulbs. caused by age and possible corrosion from water vapour (bathroom). 1 option would be IP rated integrated LED downlights
Reply to Canister lights from 1985, bulbs burn out WAY too early in the Lighting Forum area at ElectriciansForums.net
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
This is the second set which won't work to replace the current spots here in my kitchen. All they do is flash once quickly. I'm replacing...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
