I
iamelectric
does anyone know why the waste pipe coming out a combi boiler has to go into the ground or into a waste pipe , cheers
yes as stated above. I didn't know.. but I asked a plumber mate of mine. i know, but he comes handy sometimes!http://www.wte-ltd.co.uk/condensing_boilers.html
It's acidic
It's acidic
It's acidic
my sister just had a combi fitted and they just popped it thru the wall , dripping down the wall onto the ground outside , charged her an arm and a leg too
or a trace heater.
Problem with condenser outlet pipes is they can freeze solid in zero temps, then water backs up causing a fault on the boiler. bit of lagging outside would do the trick.
but look at the amount of energy that's wasted installing solar panels.. scaffolders time and energy + wagon fuel. roofers ditto, sparks ditto. all the energy utilised by the suits in their plush, warm, well lit offices writing the rules and processing the FIT tariffs. need i go on?
It can be a problem if you run the entire length in overflow pipe which is about 22mm diameter. That's generally the size of the pipe that exits the boiler, but the "better educated" amongst us will immediately connect that into a 32mm - or even a 40mm - once it gets outside the building.
Run it in a downward direction as near to vertical as possible and tip it into a soil stack using a strap-on boss ... Ohh Missus!!!
I have never known one to freeze yet.
