Discuss External Emergency lighting in the UK Electrical Forum area at ElectriciansForums.net
There is high level emergency lighting where I work. It keeps switching itself on and off whether the sensor is activated or not - its on timer so shouldn't be changeable like this.
Anyone have an idea of the problem?
Are they coming on when it gets dark, they could be maintained fittings being switched by a dawn to dusk sensor.
Not much good in an emergency if the timer switched it off
Just a thought with LEDs do they keep the batteries warm enough when used outside when temp drops below 0 deg. Do you make any special provision? As my work is mostly in warmer climates just wondered.
Reply to External Emergency lighting in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi folks, Can anyone recommend a reliable brand for emergency lighting bulkheads please? I have a job coming up to replace 30 odd units. I have...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
I've been asked by a client to 'mask off' the green LED charging indictor lamps within several emergency lights fitted within bedrooms on a...
