- Feb 25, 2024
- 19
- 10
- 50,033
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
I have an FCU, through my conservatory wall.. it was intended to be for a pond pump, but, can I, have a set up where I can use the same FCU, but switch between the pond pump and a light in a lamp post thing? I appreciate any advice!
