L
LlandrilloSpark
Fellas I'd appreciate any thoughts on establishing the correct BS number for the cut out in the attached pics, the head is actually rated at 30 amps max but the cut out fuse is rewireable (3036?) and has been wired with 60amp wire.
There is no earth rod and its not TNCS/PME as its not available in that area, earth is taken from two grub screws on the cut out casing, the main earth before i rewired the house was 1.5 aluminium stranded!, ive replaced with two 6mm's until my new lugging tool arrives on friday when i will replace with 16mm, Ze was 0.21 rewired
Cheers
Mike
Cheers
Mike
