- May 25, 2011
- 6,161
- 7,152
- 10,256,798
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
Evening all,
I'm slouched over the bar tonight, wondering what on earth to do with this:
Very long story cut really short - expensive prestige domestic new-build in the middle of nowhere, I won the tender (awarded by the customer but my client is the builder) and the project has done the usual trick of running way over time and budget, tensions and politics running high and the builder is a whisker away from being dismissed (his site foreman/QS has already been banned from site!).
Various threads are on here about different bits of it. Yesterday, due to the chippies having to strip back a wall because it was as bowed as a banana, I realised that it's very wet inside and wasn't keen on reinstating the wiring in that condition, so flag this up as needing inspection - get the biggest load of BS from the builder I've ever heard, so say that I won't sign it off unless the architect or BCO write me an indemnity. Builder says he'll talk to the architect, which I doubt very much. So that has set the tone for this little gem..... I flagged up back in NOVEMBER that there was a loading issue and that no-one had consulted the DNO about installing a ground source pump. In addition, this place has it's own private water plant plus a few other bits, and the loading calcs were creeping up and up. Tony and I were discussing this in part on a thread on here to do with the transformer feeding the place off the OH lines, and we ended up going over all my figures together on private email just to double check my thinking and he is in agreement, as to are a few other 'notables' amongst us, so I'm fairly sure in my standing on this. The results back from the DNO were that they needed to upgrade the transformer by a little bit, I told the builder the estimate from the DNO and life carried on.
Except that the builder has constantly stalled on telling the customer, and DNO have a 6-8 week lead time from order (place is due to finish end of next week). I got bored of this today and confronted the builder, who then span me some complete out of the blue line about having been consulting with some E&M consultant behind my back and how they were saying it doesn't need doing. Now, the fact that I am the only person on the planet that has knowledge of the full design, specs, loadings etc at the moment then how the hell some desk-driver can produce figures without talking to me is beyond me. I kicked off and stood my ground, stated very clearly that I'm not prepared to put my name and reputation to something I'm not happy with. Now, I have a deep suspicion that this E&M bloke may not actually be involved and it was just a line to try to deflate me, BUT if some set of alternative figures appear, which CAN'T be based from the normal methods prescribed by the regs, where do I stand??? Haven't called the NICEIC but they're not likely to be much use as I think they'd deem it to be a design issue (??).
This could become a contractual issue, and there's a hell of a lot of ££££'s left to collect in.
Sorry it's long - but I promise you this IS the short version!!
