Discuss Installation of oven outlet in the UK Electrical Forum area at ElectriciansForums.net
cyrus_mc
The house I purchased a few years back came with a gas oven. I am looking to upgrade to a duel-range oven (gas top, electric oven) and therefore am looking to install an outlet where the stove is.
My plan is to install the outlet myself and run the wire to the box and then pay a professional to actually tie it into the box. I also plan to run the wire through the crawl space and across the floor truss (as the oven is on the opposite of the house where the electrical box is).
Two questions:
1) is it recommended/safe to run the wire through the crawl space as I have suggested
2) can the wire be exposed or should I run it through conduit (medal or PVC)
Thanks in advance
contact an electrician first. Tell him your willing to do the leg work. Run cable. He can advise you and quote for works at same time.
im always happy for customer to run cables. I hate crawling through small spaces. Basically you paying me electricians rates for something anyone can do. I will then do what I am paid to do. The electric connection side.
100% this , I can never understand why people don’t do more of the donkey work themselves.
I am more than happy for customers to rip up floors , chase walls and even pull in a cable if they really want to.
Two questions:
Thanks in advance
Yes to question number 1 and question number 2 is the wire has to be weather resistant to run under your house and it needs to be 4 wire. 2 hots 1 neutral and 1 equipment ground
Reply to Installation of oven outlet in the UK Electrical Forum area at ElectriciansForums.net
I am getting ready to install a new wall oven that's about 4 ft closer to the panel than the old stove. I have about 4 ft extra cable with the...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
I am thinking of getting an Electric vehicle. The only way for it to be realistic is to home charge. The problem, I have a fuse box no breakers...
Hello hope you can help I have a single oven 2.4kw max and a ceramic hob 6kw max I would like to put then both on the same circuit so i was...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
