Discuss Is it a tt supply in the UK Electrical Forum area at ElectriciansForums.net
Can't help wondering what the separate RCCB is supplying.
Has all the hallmarks of an electric shower with no overcurrent protection, although the round cable suggests I could be wrong.
Yes it is possible to have an underground TT supply. Any supply can be made TT if required.
However it more than likely has an earth connection available that nobody has yet taken advantage of.
Contact the DNO to check the availability of an earth.
Thanks, yes they are getting a survey from Dno to see what can be done.
I would be a bit shocked if it is a TT system in.
looking at the area it looks like NEW BUILDS there (within a few years)
"The new wording within Regulation 411.4.2 is the final paragraph, where it introduces a recommendation that an additional connection to Earth by means of an earth electrode to the main earthing terminal. ." Taking for Napit site
i did notice the Sticker 25/08/23 and i wonder how old the house is
(hope this is within this site rules)
Reply to Is it a tt supply in the UK Electrical Forum area at ElectriciansForums.net
Afternoon All, Just pricing up a job and thought I'd pick your brains. Quick run-down, Block of Flats with an underground car park. In the...
Need some advice, I have 7 static caravans to connect which need to be connected via TT 1. All the vans have a 30ma RCD main switch internally...
Hi all, Would like some advice on the below. Context: Rural French domestic installation TT system Earth rod is situated inside the property...
I have been asked to provide a quote for a supply to an toilet block on a campsite. The three phase supply to the campsite is approx. 150m from...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
