Discuss Is this a smoke alarm or sprinkler or both? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
HappyHippyDad
As in the title, which is it?
I'm carrying out an EICR and there is a circuit labelled 'smokes' but I am not used to seeing these in a domestic house. This is in a block of flats.
Is this a smoke alarm or sprinkler or both? smoke - EletriciansForums.net
Cheers all.
Does look a bit odd my only thought is if it is a sprinkler it is a bit close to the smoke detector and would stop the water reaching part of the room.
Is it one of those smoke detectors with a combined emergency light?
Whenever I've seen an emergency light on a smoke detector it's been on the head as for a neon even the old ones from the 70's have had a small neon built in nothing as chunky as that.
you're all wrong.it's a flying saucer from Mars. the stub is clearly the exhaust, used for hovering, like a Harrier.
Reply to Is this a smoke alarm or sprinkler or both? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
