Discuss Is this a smoke alarm or sprinkler or both? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
HappyHippyDad
As in the title, which is it?
I'm carrying out an EICR and there is a circuit labelled 'smokes' but I am not used to seeing these in a domestic house. This is in a block of flats.
Cheers all.
Does look a bit odd my only thought is if it is a sprinkler it is a bit close to the smoke detector and would stop the water reaching part of the room.
Is it one of those smoke detectors with a combined emergency light?
Whenever I've seen an emergency light on a smoke detector it's been on the head as for a neon even the old ones from the 70's have had a small neon built in nothing as chunky as that.
you're all wrong.it's a flying saucer from Mars. the stub is clearly the exhaust, used for hovering, like a Harrier.
Reply to Is this a smoke alarm or sprinkler or both? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
Hi Guys, just before i call the sparks out, am i able to remove a smoke alarm and get it in a junction box in a bedroom? they are hardwired so it...
