Discuss Lightswitch wiring from 4 wires to 2 wires? in the Lighting Forum area at ElectriciansForums.net
Hi
I am trying to wire, what I thought was a simple, light switch. The problem is there are a lot of wires from the previous fitting going into a new one.
Can someone help me to sort out wiring for the new switch. I have attached two images one for the old wiring and one for the new one.
https://Upload the image directly to the thread.com/2qxRoCN
I can't open the image.
It may need a mod to review it...
Seeing as the OP is a new member, are you lot are eager! , here's the image he tried to link to... (I think Upload the image directly to the thread is not supported with html/bbcode)
https://i.Upload the image directly to the thread.com/2qxRoCN.jpg
What switch was in before OP.
If you got like for like then just ensure terminals are correct.
Also ensure your new accessory screw is not long , as that connector block is lined up perfectly to hit it.
I'll try adding images on my own server:
Original
New One I want To Add
totally wrong. original switch is double pole. new one is not compatible.
Ok. You will need a piece of insulated terminal block.
Put the twisted together black cables and the single black together in the terminal block.
Then the twisted reds in the common terminal on the switch. The single red in L1.
Then, and this is important, you must have a length of earth wire from the earth terminal on the switch to the earth wires in the back box.
The most valuable advice I can give is Make sure the switch is right way up because it will look like it's off when it's on and that will proper p**s the misses off.
Yes, why don't you ask then?
But, from the nature of the post from our new friend, the OP, I rather suspect that he will not have any idea why.
Maybe the installer had one spare on the van, or they were cheap on eBay. There's so many possibilities. But do ask him, or do you want my mum to ask for you?
You have it about you tonight TTC!
Want to talk about it?
Reply to Lightswitch wiring from 4 wires to 2 wires? in the Lighting Forum area at ElectriciansForums.net
Hello, I’m trying to change a pendent light, I’ve wired it the same as the previous light that was on there however the light is now permanently...
Hi Total novi e but have wired multiple light switches previously and survived :) I've bought a nice WiFi enabled dinner switch for a new LED...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
I have an outdoor light I am trying to hookup. There are two wires coming in with a white, black and ground. One is coming from the breaker and...
hi could some one please help me with the wires on this light switch please i need to change it to a new one any help would be apreciated thanks
