Discuss Mains water bonding when only couple of inches of copper in the UK Electrical Forum area at ElectriciansForums.net
n180
Not sure on this one.
Mains water is coming up from the ground in lead pipe in bathroom. 2 inches of copper pipe before the stop tap. All pipework inside the house after stop tap is plastic.
Does that 2 inch of copper pipe before stop need mains bonding?
That's what I thought also. Any reason it might not need bonding? Because I'm just looking at an installation some builders have done and they didn't bond it on purpose. So before I speak up I want to be sure.
If its accessible then it needs bonding and even if it wasn't accessible I assume it still would anyway. Lisa Shaw was killed when she grabbed an earthed stop tap whilst kneeling on a wet floor that was electrically charged. Ironically it was probably the bonding that killed her but if its metal and coming out of the ground like an earth rod then it 100% needs bonding.
edit : It was Emma Shaw that got electrocuted, Lisa Shaw was killed off by the rona jab.
Reply to Mains water bonding when only couple of inches of copper in the UK Electrical Forum area at ElectriciansForums.net
Greetings, I am homeowner and looking to confirm if I will need earth boding to water pipes. There is already earth boding near Gas meter and the...
No waffling, going to get straight to the point. Main water on the exterior of the building in plastic. Changes to copper inside the building...
Hello, Carrying out remedial work on a commercial site and I've come across a metal out building that has a water supply to it. The water pipe...
What are the regulations requirements on Earth bonding ? I am currently planning a 1st fix re wire I have the following setup Gas Meter...
I have a main panel beside my meter on the house built in 1987. Then a 4 wire feed into a 200 amp panel on an inside wall of my basement. All of...
