N
nick611
Can anyone help with this..2500w of panels. 6mm cable. Max length of run?
Discuss Max length of run? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Not my area of expertise, but on your panel spec you should have the voltage,
multiply this by 11 (if you are running on one string) then you will have your DC voltage.
When you say the voltage fluctuates do you mean the AC or DC?
really long.
66m before you hit the 1% volt drop threshold, but it's only 1.5% at 100m which can be acceptable in some circumstances.
ps sunny design is your friend for this sort of thing.
where it's not cost effective or practical to move up to 10mm2 cable. TBH I'd only consider it for bigger systems, never go above 6mm2 on something that size, though I guess I've also never gone above a 66m run for a system that size either.thanks gavin. what circumstances are these?
Reply to Max length of run? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
