Discuss Megger MFT 1552 fault in the Electrical Tools and Products area at ElectriciansForums.net
M
MacLec
Hi,
Borrowed someones megger 1552 today to megger an alternator @ 1kv and check windings.
now keeps showing battery symbol on IR test
It was showing fuse symbol as well earlier but not now.
Fuse is not blown (checked with fluke) and new batts reading 12V
anyone had similar - looked through threads cant find anything.
Was dead testing....
Hi,
are you using rechargeable batteries?
Hi,
Hi Mac,
Had a similar problem with a works MFT 1553 last year, checked batteries and replaced for new ones but it was still the same, so checked the fuse and noticed the fuse carrier was quite loose around the fuse (correct fuse was inserted), so tightened it by squeezing with long nose pliers and put fuse back in and checked it against the calibration checkbox and log and all was good, was working flawless until apprentice blew the fuse a few months later !
Hi Mac,
Had a look in there was ok, took it to get repaired guy in shop showed me output voltage was knackered so prob fried the tx in it. Can rember one of the leads falling ouy during a test its a bit hazy but i might have been live when i re inserted the lead.
Guy says hes fixing it for 75 so not the end of the world lol
Just wish it was mine and not someone elses, why couldnt the job havr waited till today is my fluke 1652 c has just arrived ....
Reply to Megger MFT 1552 fault in the Electrical Tools and Products area at ElectriciansForums.net
Bit of a long shot on here but does anyone have a circuit diagram for a Chavin Arnoux CA 6545 5kV tester? I've copied my post on EEVBLOG forum...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
Picked up a 2nd hand megger mft1721 yesterday after my tools got stolen from my van and needed one in a hurry 😡 Seemed ok when I picked it up...
Recently changed a CU for a friend and today when visiting one of the RFC's RCBOs tripped. It was due attention anyway as open ring and no time to...
