cliffed
2,210
700
102,788
Worcester
United Kingdom
Electrical Engineer (Qualified)
Struggled with this yesterday & cocked up, would it still be ok to leave this & mark the appropriate terminals differently.
Load in the wrong terminals,it’s a 35mm Swa sub main, still got tails to connect into
Do you mean you have load on the feed side, and feed on the load side?
If so, not really, the fuse would still be live and connected when "switched off " - the live feed is supposed to be isolated from the fuse by opening the switch.
Yea…oh dear might be a problem then
Crimps and heat shrinks in in order.
is there enough slack in the SWA to lift it up and enter the enclosure higher up, soas to reach the top terminals?
Reactions: Dustydazzler
Kicking myself made the other end off ok…just got mixed up with the in & out…reckon I maybe able to make off again & gain a-bit..hopefully..it’s not the greatest S/Fuse for 35mm..the earth only accepts 16mm.
I doubt it gonna try & move to the left & gain a bit
I would screw a new earth bar at the top of the board
Re-terminat swa in the top of the board , put tails gland in the hole at the bottom
bingo jobs a goodie
The Swa comes from a duct,& the enclosure tight to the floor
That will teach you trying to get a python in a little box snake chamber you. Lol
  • Funny
Reactions: pc1966
Set a task & failed…?
Might just have to be solder/crimp and heat shrink and run them around the right of the switch. It looks ‘close’ Will it shove along to the left at all?
I’ve made a similar mistake once. (Assumed old switch and new were the same in my case)
Reactions: pc1966
Thanks for all replies will try & gain a bit by moving to the left off to another job now have a good one?
Got one of those to do on monday with a 35mm swa. What size are the earth terminals on the main block -
As a last resort maybe change the switch for one that has line in at the top, like this Lewden fused switch for example
I also thought that and I like the idea but you can't terminate into the side of those so it might not work for OP.
Also the load L connects top left, but it's probably long enough.
Are the earth terminals 32mm on these?
Cheers will have a look that maybe the solution ?
As a last resort maybe change the switch for one that has line in at the top, like this Lewden fused switch for example.
I'm that particular unit doesn't accept side entry which is absolutely useless. Fitted 2 last week and was fairly dissapointed with the quality of them.
Ok I reckon will re do & see how much I gain on the Swa…
16mm mate?
It's hateful when things like that happen. It's the sinking feeling when you see it afterwards. We've all been there
Exactly! But for the grace of God go I...
Recently I realised I had punched out the top hole on a rotary isolator's case. Thankfully I found I could just remove the switch mechanism and turn it over. But it still annoys me one is in right and the other is almost the same but not quite :(
Yea I actually didn’t see it on site.. went to bed & it just came into my mind did I actually connect it that way…looked @ the pics in the morning & there it was….shocker?
What was the outcome?
cliffed
Worcester
United Kingdom
One of those days
cliffed,
IAmSparkytus!,
