H
harvirsingh
calculate the desgin current of the radial circuit suppling the air compressor ( circuit BR4)
i need help with this ASAP please
Where would you.find the current rating of the air compressor?
As per @i=p/u you’ll need to know the current rating of, in this case the compressor at the end of your proposed circuit, they must’ve given you some numbers to work with?….can you share them with us?
Reactions: DPG
As above, you should have been given more info for the question.
Also, when you find the full question, we would like to see what results you get. If your result is incorrect we can help you with that. Us just telling you the answer is now a good way of you learning.
Reactions: DPG and Baddegg
question 6 in current design
harvirsingh,
Spoon,
