Discuss Relay problem with air horn in the Auto Electrician Forum area at ElectriciansForums.net
L
lelstacey
Hi,
I am trying to fit an air horn to my boat (same as car electrics but without the ECU).
i think the relay is wired wrong because without relay it works & with relay it wont. i put a tester on all connections & the switch is providing 12v when pressed & the constant from the battery is also providing 12v.
I did notice when i wire it one way shown on the internet i hear a click straight away as i ad the last wire even before button pressed (30 to battery+, 85 to earth, 87 to horn+, 86 to Switch) but no sound from horn, when i swap wires to match chinese instructions no click as it should be but still no sound from horn when switch pressed.
as horn works when connected direct to switch without relay using same wires just block connecting in place of relay. i can only assume the relay has been put in the wrong way round inside so the pins are not as numbered?
my question is, as when tested no fuses blew am i safe to use without the relay?
If you hear a click without connecting switch wire...then swop 30 & 86
As to using a relay, it will depend on how much current the horn draws.
ah, i see what youre thinking re click :) cant rember if that was the other way i tried but will check as i did write it down on the boat & if not will give that one a try. thanks
IN A WORD NO! Using that horn without a relay is guaranteed to damage something either switch or wiring,wire as follows. take a live feed via a fuse to terminal 30 then from terminal 87 to positive on compressor, take positive from original horn to terminal 85 and then a negative(earth) to 86 and it should work.do NOT attempt this without a relay the current pulled by the compressor is way to much for the existing circuit.
Reply to Relay problem with air horn in the Auto Electrician Forum area at ElectriciansForums.net
Hi all, the main horn on my Fiat Punto stopped working - went around the houses to fix it including the clockspring but to no avail. Now wired up...
Hello folks, So my van got found after being stolen ;D Now I'm installing my own alarm on the van which is triggered when a door is opened. Im...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi I’m stumped and can usually figure it out after a while but not on this one. so I joined here In search of some help on my 05 tundra I’m...
Mileage: 112223 - DTCs - P0480 cooling fan. Also codes in TIPM P0691, P0692 for cooling fan control circuit. Tests/Procedures Performed: 1...
