Amp David
Mentor
Supporter
Oct 2, 2009
4,930
915
10,239,798
Glossop
Looking at getting myself a socket set, but wondered which size most electricians use on a day to day basis, 1/4 or 3/8 inch.
Cheers
A 1/4inch set is most likely to be more useful to you as it will contain more smaller sizes of socket than a 3/8.
I find a combination of an adjustable spanner and a universal socket like this:
cover most situations.
socket set
i sure i have seen them in store for 20 quid. decent enough looking set.
also the professional ones from halfords are not much more and come with the lifetime g/tee
halfords small 1/4 set is Ideal backed up with 13,15,17,19 on a 3/8 set and a couple of 10 13 15 rachet spanners
24,25mm canny mind other sizes iv got about 6 box spanner for 20mm glands in boxes where glandies wont fit
i have a draper, 3/8 and 1/4. it's a unique design , as it has a set of "through sockets". these allow to run a nut up say, a threaded rod without the end bottoming in the socket. was about £40
same style, open end ratchet, but mine is a hell of a lot more, about 60 pcs for a lot less. shop around.
same type, draper expert? only thing i found is the ratchet sometimes slips, but draper have a no quibble replace if faulty scheme, so go ahead and buy.
steve, that's exactly the one i've got. was £44 about 2002 i bought it. can't fault it in any way.
agree with lenny, the halfords gear is spot on, and very cheap too. lifetime guarantee as well.
Amp David
Mentor
Supporter
Glossop
Small Socket Set
Electrical Tools and Products
Amp David,
Amp David,
