Hi all, does anyone know what sort of controls are required for solid fuel appliances.
I have scoured the net and have seen various set-ups which has probably confused me even more.
I have limited knowledge on the plumbing side apart from knowing that it is a boiler behind the fire to heat the water and take it to the cylinder via gravity.
There is a tank on a shelf above the cylinder, with a cold feed i believe, a ball valve inside, and another pipe coming from this tank, which goes outside, overflow i think as this one is plastic.
There is also a pipe coming out of the top of the cylinder with a t piece joint in it. One pipe goes up to the header tank and another goes to the pump
The pump on the pipework will be used to heat some radiators, and that is it. There are no zone valves to be fitted. Dont know much more about it yet.
My first thoughts are that i would need a high and low limit stat for the pumping side and some way of deciding on when to control the heat to the radiators.
Waiting to get more info from the plumber
