Hi everyone,
I am digging the trench for 25-30m of 3x6mm SWA from my house's CU to the (yet to be installed) summer house. 95% of the length will be under a new stone patio. This is part of a major back garden landscaping project which I challenged myself to do on my own (most of it anyways). The electrical connections, testing and certification will be done by a qualified electrician.
The problem I have at the moment is that I hit a particularly tough and compacted layer of stone / concrete / rubble at about 35cm depth. Other than sparks from the pick axe and a colourful language, I am really struggling making progress.
I was initialy aiming for 400-500mm depth but I am now wondering if 350 would be suffient in this case. I'm pretty confident the cable will be safe from any forseable mechanical intervention, short of a power digger and a over enthusiastic operator ignorig the tape.
The SWA will be inside a 32mm "heavy duty" PVC pipe together with 2 x outdoor grade Cat6 STP cables and a pull rope. This will sit on a thin bed of sand, followed by more sand, 10-15cm of compacted Type 1 sub base, Yellow warning tape, 5cm sand cement mixture and 3cm of paving flags.
Your thought on this are greatly appreciated.
Best,
Andy
Best,
Andy
