Discuss Tns? in the UK Electrical Forum area at ElectriciansForums.net
ses
Seen a few of these 3 phase supplies with this earthing
Cant quite tell if the earth bar is going into the neutral or just being held in place by the cover
Seperate 16mm earth comea in with the supply cable no lead sheathing
Is the line/earth reading the same as the line/neutral reading? The separate cpc may well go to a stake, it is probably TN-C-S, it is very difficult to confirm without further enquiries.
Excuse me??? There is a specific reason why the DNO would supply the property with tN-s or tn-c-s its not your decision!!
I never said that it's your choice, I said that they have a link so they can be used for either, a photo of the outside doesn't show anything as the link could be in place or not.
Reply to Tns? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Hope you're keeping well I'm currently wiring a small commercial premises. 3 phas incoming supply, 16sq cables As it is in an urban...
On an EICR I found a 200 amp 3ph supply, TNS earthing (which looks original) and Ze of 19 ohms. No rods. No RCDs. L1 -> N was about 0.5 ohms...
Please can someone explain if this is a TNCS or a TNS earthing arrangement because it looks like both to me. Old undersized main bonding conductor...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
