Discuss Underground Cable Testing in the UK Electrical Forum area at ElectriciansForums.net
I'm guessing that the question is whether an Electrician or a Professional (e.g. Electrical Engineer) should conduct the testing.
It's only a guess though as it clearly isn't what the question asks!
Most certainly if that is the case then an Authorised person, or an Authorising Engineer fully trained with a current APicket should be carrying out the test.
To add it would be a difficult procedure to test without first termination, you never know what damage could be done during the cable termination.
As Pete says cable must be terminated, I am no expert in such matters but I believe the test voltage should be AC at twice Uo. These cables have specific insulating properties and you should seek advice from the manufacturer or seek expert help, not mine! You liven that cable up and there is a problem you are likely to be doing more than just resetting a breaker from the fall out.
It does matter, it is a complex and extremely dangerous test to carry out involving 20,000V+. The one saving grace is it would be highly unlikely he could get his hands on the equipment needed.
If he has a legitimate reason for asking I’ll provide the latest test procedures.
Reply to Underground Cable Testing in the UK Electrical Forum area at ElectriciansForums.net
Afternoon all. Was wondering, when cables are run underground using mole/tunneling methods, how do people get around the requirement to mark...
Hi, I'm running a 70ft underground UF cable in 3/4 inch PVC conduit to 2 sheds. The sheds are 3ft from each other. I'm just a DIYer enthusiast so...
At the work place. When proving an 11KV Transformer is Dead. We have HV test sticks. With a function test. Part of the procedure is to function...
Hi, I'm going to be wiring up my garden office with power and ethernet underground and I need advice on the best way to run the cables as I have...
Happy New Year all. Quick question regarding cable sizing. I have a 25m run from DB to car charging unit. The 25m run will mean approx 8m is run...
