Discuss What do i do now! in the DIY Electrical Advice area at ElectriciansForums.net
ok so i wired up my pendant light but took it down again because the skirt wouldn't screw all the way up on to my existing ceiling rose because of the nut and that pushing against the wires (13 wires in there so not much space).
I dont think i can just use the metal light socket of my pendant light so what do i have to do in order to get this flush to the ceiling please?.
I have no idea about this sort of stuff.
The new fitting must have come with a bracket because that will not thread to a ceiling rose base.
hello
yes it did but i couldn't screw it all way up because to many wires i think pushing against the metal nut.
I dont know how to go about it.
The ceiling rose needs removing and conductors connected as flat as possible using 221 Wago connectors within the new ceiling cover. Can you show the inside of the old ceiling rose.
The ceiling rose needs removing and conductors connected as flhmmmm think it be better to wait until i can find someone to do it for a score
hmmmmm these pics are not crystal clear but ok ish
Does the bracket not fit over the rose base.
I am not convinced the lamp holder does not require an earth. Can you get it apart.
Didn't we have this same thread the other day?
Similar but a different light and different person.
I think.
No it is the same person but I just let the thread roll.
Reactions: DPG
Reply to What do i do now! in the DIY Electrical Advice area at ElectriciansForums.net
Hi, there are 3 bundles of wires coming from my ceiling and I've been told they have been tested with a multimeter and have all got a current but...
Hi everyone, I really hope someone will be able to help. So last night I tried to change 2 ceiling rose / pendant lights at my mother in laws...
  • Locked
I've wired up my spots however the main light [the one that was once a ceiling rose] works as intended with the light switch, but the rest are...
Hello I have moved into a new house and the electric meter and consumer unit are under the stairs. What i want to do is put a door there so can...
