Discuss What socket is this? in the Lighting Forum area at ElectriciansForums.net
personally I'd replace that holder with a E27 and fit a LED lamp (bulb)
That looks like a socket for a compact fluorescent lamp.
If you change it to a normal light socket then you may well need to remove the controll gear Fromm the fitting.
Hi James, so would you say a G24q-2 bulb would fit this? I've seen there are 3 different types of G24q's and not sure which would work.
As you mention, there are several variants of G24q lamps, with 2 or 4 pins, and some with tabs that fit cut-outs in the socket in a specific place - designed so you can't put the wrong lamp in the lamp holder.
in the past with a non-standard variant, I've taken the old lamp to somewhere like CEF, and checked the new lamp base is identical before buying it.
Reply to What socket is this? in the Lighting Forum area at ElectriciansForums.net
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
I have halogen lights in my kitchen under the wall units, there are ten lights altogether bulbs are either 10 watt or 20 watt G4 bulbs ( not sure...
I disassembled a Christmas light projector to try and identify the cause of why the images from the projector weren't moving at all, when they...
Have you got any plans for the long Easter weekend? Here in the UK Friday and Monday are both Public Holidays so a lot of people have a break or...
This is the second set which won't work to replace the current spots here in my kitchen. All they do is flash once quickly. I'm replacing...
