K
Ken77
Hi all,
I've just been to test a number of faults and have found a number of classrooms have relays on fluorescent lights? Can anyone think of a logical reason why someone would have installed them like this?
Thanks in advance.
So that they can be switched by timers and or photo cells perhaps.
How many lights to each cct, relay/contactor?
What he said^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Depending upon the classroom there are between 4 - 8 twin 5ft tubes per relay.
I can see any evidence of a timer, (not to ay one does not exist).
Currently controlled via a 1 gang switch - which is why I can't see the point of the relay.
its normally like that if the design current is too high for the switch, so this way the switch only carries the load of the relay
I haven't yet determined if all the classrooms are on the same circuit, but there is a relay in each classroom. What where you thinking?
the load is distributed through the relay instead of the switch. how many channels on the relays are in use?
Could be linked to an alarm system to switch on the lights if there is an alarm. ie the security alarm.
you can't be looking at more than a few amps per circuit and if their controlled by a suitably rated switch can't see the point in relays really
Nor can I. I was trying to understand why this may a have been done as I am not familiar with use of Relays. Thanks for all the help.
Fluorescent lights and relays
Ken77,
Marvo,
