OP
Octopus
Plug the tester in.... Notice it's loose, and watch the readings of the volts change as you change the position of the plug in the socket....
Discuss Intermittent sockets, wiring and fuses fine in the UK Electrical Forum area at ElectriciansForums.net
Right thanks.Plug the tester in.... Notice it's loose, and watch the readings of the volts change as you change the position of the plug in the socket....
Heard of a socket tester, and I knew what the OP meant, I thought it was street talk for putting his socket tester in, nearly went to my post box to see if the postie had rocked some letters in for mePete. Haven't you heard of a shake, rock it, socket and see tester? Almost as good as Megger
Its a technical term."Rocking my tester in the socket" what does that mean?
Dumbest technical term Ive heard of.Its a technical term.
Reply to Intermittent sockets, wiring and fuses fine in the UK Electrical Forum area at ElectriciansForums.net
