Right some back story
we rent a unit, 3 years ago they upgraded/updated the old consumer unit (metal, pull out fuses to a crappy plastic crabtree ) as they said they needed to for new regs / insurances etc
now get a letter through as there 3 years old there due for inspection and testing (the normal lot) thats fine
they come out 2 hours later they say your failed right ok what on
1, sockets arnt earthed (10 or so sockets fed from 20mm conduit and thats fed from 50x50 galv trunking they say it requires its own cpc (check pic out)
my question are they correct or does the conduit and trunking surphise / accactable and why didnt they pick this up when they changed the board ?
2, my 3 phase spot welder isnt earth and you cant use the swa as an earth as it doesnt have banjos on the metal boxes either end so need to be re run
my question i think this is bollox but at most it just needs banjos fitting
right or wrong?
the install was done 20 or so years ago if it matters by a commercially sparky
pics below
any questions or more pics just ask
ta shaun
right or wrong?
pics below
ta shaun
