Discuss Need Some Advice / Guidance in the Commercial Electrical Advice area at ElectriciansForums.net
I can not see any earthing conductors at the mains intake.There is nothing wrong with using the trunking and conduit as the C.P.C. but I can't see how this is earthed back to the consumer unit.
this is where the stupid sparks came in
they removed a metal board which the conduit was connect to it, and shoved a plastic crappy one in but not redoing / terminating the earth so atm its not earthed as i would of thought they would have done it when they changed the consumer
Understand. But AB is saying there should still be a main earth terminal....the original metal board should have been connected to it.
yea there is on the side of the main i guess you would call it fuse holder (main incoming supply)
tncs supply if it matters
Just couldn't see it in the photo and I thought it was the case regarding a metal conduit from the old metal C.U. to the trunking being removed and replaced with flexible PVC conduit removing the earth continuity.
No sorry but it was the same connection as the sockets
Coupling and brass bush
Only know this due to the coupling still being on the end of the conduit :D
Reply to Need Some Advice / Guidance in the Commercial Electrical Advice area at ElectriciansForums.net
So I'm starting out a new rig and I'm fresh out of college with my level 3 without any experience and I think that I need to still have the...
Need help with a quote here. I’m wanting some sound advice. Was called out to the hot water not working so repaired the issue within the panel...
