right had an hour to spare
tested from the earth point in the isolator (spot welder end) to armoured sheath and got continuity
other end tested from earth point on the fused supply to the armoured sheath and got continuity
now tested from earth point in the fused supply to the met and got continuity
my question
from the met to the earth point in the isolator (spot welder side) via a fly lead what resistance roughly if any am i looking at
Your looking for a low resistance, if you have a multifunction tester I'd advise you carry out a Zs as well
all depends on the csa of the cable or the armour and it's length. figures can be obtained in the osg.
ta will try and find the table
what sub 5 ohns ? and dont have a mft (not a sparky)
what are you measuring? a core conductor or armour?
earth path eg from the isolator by the appliance to the met
as the testers say theres non / not upto standard
as i said, the resistance will depend on what you are measuring. what size MCB is feeding the circuit? e.g. if a 32A type B, then i'd expect the resistance to be less than 0.5 ohms.
Reactions: Corbs
no mcb but 32amp replaceable fuses (i think there type 269)
so definitely less than 0.5 ohms, depending on the external Ze could be less. no way to determine without using test meter/s
  • Winner
Reactions: Corbs
thats fine least i have something to go off
I can not see any earthing conductors at the mains intake.There is nothing wrong with using the trunking and conduit as the C.P.C. but I can't see how this is earthed back to the consumer unit.
Reactions: Corbs
this is where the stupid sparks came in
they removed a metal board which the conduit was connect to it, and shoved a plastic crappy one in but not redoing / terminating the earth so atm its not earthed as i would of thought they would have done it when they changed the consumer
Understand. But AB is saying there should still be a main earth terminal....the original metal board should have been connected to it.
yea there is on the side of the main i guess you would call it fuse holder (main incoming supply)
tncs supply if it matters
Just couldn't see it in the photo and I thought it was the case regarding a metal conduit from the old metal C.U. to the trunking being removed and replaced with flexible PVC conduit removing the earth continuity.
Reactions: Corbs
Yep another thing for me to sort / fix
Well you would think will give me a bit of ammo anyway
I'd call that a BAZOOKA.......not installing a main earth:mad:
No sorry but it was the same connection as the sockets
Coupling and brass bush
Only know this due to the coupling still being on the end of the conduit :D
wales
Other
Need Some Advice / Guidance
Commercial Electrical Advice
Corbs,
Corbs,
