H
hallur84
Hello,
I am installing insulation in my loft and have been mindful of all the electrical cables to lights and switches. All good, as they are nicely secured to the joists - so no need to touch them.
However, there is a cable running across the length of the loft and I can't figure out what it is for and I am hoping that you good people may have come across something similar.
I have attached some photos showing one end of the loft where the cable disappears into the wall (photo 1) and the other end where it goes down behind the plaster board (photo 2). At one point the cable seemed to be taped and a thin grey wire comes out and disappears down through the ceiling. I removed the tape and was faced with a multicore cable the thinner grey cable coming of a few of the cores (photo 3).
I'm really puzzled to what this could be! I have a voltage detector pen, and it beeps intermittently when I touch the cable, so I think that there may be some current going through.
Some things, which I think that I have already determined, which may help.
- It is not coming from an antenna or the sky dish (can see these cables, and they are routed differently).
- My house is a semi-detached house, so the end in photo 1 may go into my neighbours loft. I have still to ask him if he knows about this cable.
- The cable comes down (photo 2) almost above our combi-boiler, however I had that replaced 2 years ago and have never seen this cable, so it is not routed towards it.
Ideally I would like to either remove or re-route this cable, as it is very stretched for its entire run. I am not sure why, but there is no slack in the cable and it seems to be very randomly routed across the loft.
If anyone has any idea what this cable could be for and if I can remove it, then that would be much appreciated!
That is a telecoms cable by the look of it.
That is Telecoms cable, the blue beans give's it away.Those crimps were late 60's to the 70's.
I would ring BT , that looks like a feeder cable may be to the next property, if you look at the picture,can see the 2pair take off to your's.
Cut the cable as it goes through the wall to next door.
Then ring your neighbour, if they don't answer you've probably cut them off..
I'd also say it's a BT cable. Quite odd to see running through your property to another though as they usually want unrestricted access for maint and repairs.
Have BT been paying you rental for the space their using?
Perhaps the house was built around the cable.
Brilliant, thanks for the replies!
Although, yes, very strange that the cables runs through my loft... Especially considering that our telephone cables are underground. It might be a redundant cable from a time when they were from poles?
Also, funny with the pair which takes off (the grey cable). I have no clue where it goes... My main (and only) telephone socket is downstairs (house has 2 floors + the loft) and I'm pretty sure that it comes from the sub-floor.
Unless someone thought that it was a good idea to run the cable to my neighbour from the subfloor, up to the loft, across the loft and back down to my neighbour :smile:
I phoned BT and they were very much unhelpful. All they told me is that if I wanted anyone to have a look at it then I would have to pay £129 for the engineer... So, currently I am considering if I should just cut it at each end and terminate into a JB and wait to see if anyone complains...
Would find it really surprising if BT has decided to provide my neighbour's telephone cable though my loft - although I like the idea to charge for rental! :moneybag::tonguewink:
Will check with the neighbour before going for the cut ;)
Yes, that box is quite antique! I switched off the main breaker and had a look inside, wiring looks neat so just left it as is :)
All joking aside now. You need to trace to cable, to see where it comes from and where it goes to, before you get you chain saw out, Die Hard style. It could prove expensive, especially where Open Reach are involved.
"Will check with the neighbour before going for the cut ;)"
I'd check with the wife/girlfriend first actually...
It's quite a big decision...
Can we see inside the box.
Sometimes cables would be running through lofts for Redifusion TV signals
It's quite a big incision...
No nasty surprises and if your missus gets pregnant then errrrr your stuffed.....
IT could be a communal tv system like the old Redifussion TV set up we used to have in Basildon that used cable like that and it was run internally from house to house
This one is a little older than the one in the OPs picture.
It has a tag attached detailing the installer and the inspector... it appears to be dated 1957. And yes... that is all rubber insulation :)
Reactions: DPG and Dave OCD
Did it have porcelain connectors inside ?
No, it's a black bakelite carriage with brass terminals. It's packed quite tight and has been tinkered with since it was installed as there was a PVC cable linked in.
I'll snap some pics of the innards.
I know I'm abit weird with this, but this place is proving to be a treasure trove of old cable samples for my collection :)
OP - is it a sheltered housing esate? If so then it may be for a warden call (pull cord, etc.) system. Often use 10 core multicore as the system cable.
As promised... some pics of the 'Octopus' :)
IMG_20180222_194455797.jpg IMG_20180222_194513043.jpg IMG_20180222_194531397.jpg IMG_20180222_194642576.jpg IMG_20180222_194723145.jpg IMG_20180222_194758837.jpg
And for the younger members who's experience of old rubber cable may be very limited... here's a selection of cables. On the outside, the one on the bottom looks in reasonable condition, but when I was pulling it out, you could hear the insulation inside cracking so I peeled it open to take a look. One of the joys of rubber... over time (or with a liberal application of heat) it can dry out, become brittle and just fall away when touched.
That box was well done internally SC, and most of the lighting cables back in 1957 appear to have a cpc too ! It's a little bit of history and also a little sad as whoever did it will be very elderly or gone by now.
I was impressed when I opened it. It's possibly the part of the install that was in the best condition.
Most of the accessories have had insulation tape wrapped round conductors and one place where a bunch of cables ran near the heating cables the insulation fell off when I touched it.
The picture is deceptive though... I was surprised when I saw that CPC in the lighting circuit cabling because to that point I hadn't encountered any when cutting the old cabling out. Lots of metal switches too. Scary.
View attachment 40952 View attachment 40953 View attachment 40954 View attachment 40955 View attachment 40956 View attachment 40957
We have all been there.
Unidentified cable in loft - advise needed!
hallur84,
7029 dave,
