Hi Everyone,
Sorry for all the questions.
With he help of a friend, I recently installed some insulation into my mother's loft. Whilst adding the insulation I noticed that a few cables (there are only light related cables in her loft) were tied together with electrical tape, so I spoke with an electrician and bought a few junction boxes with wago connectors and tidied tidied them up.
Two issues that I hoped I could ask some advice on please:
1. One of the red wires was not joined properly with two cables it was taped to, after being added to the junction box, the consumer unit started tripping. I called the Electrician straight away and he disconnected the cable which stopped the tripping.
2. I also noticed that one of the cables in the loft, near the hatch had some tiny to small cuts on the outer cable. I temporarily wrapped some electrical tape around it. All of the other cables looked fine in the loft.
I would like to request some quotes for the above to be looked at and hoped you might be able to advise on what to ask for please. I don't know if all the loft cables should be tested or if I should be asking for the un-joined wires from number 1 (above) to be tested and for the cable from number 2 (above) to changed or renewed. I would really appreciate any thoughts on this.
Thank you so much in advance,
Vanessa
Vanessa
