C
The length of run is 80m though
.That’s the length of cable OP has in his garage.![]()
It will be Sat on decking with around 2/3ft surrounding before it turns to grass again
the fused spur will burn out if above the rated birth bath.swa from a 16 amp mcb in the CU to a IP66 RCD switched fused spur (Aprox 25m fro
Thanks for the dumb all I asked was how you would get the 10mm into the spur/FCU an answer would have been sufficient if its advice you want from me then forget it.Hi, I've been asked to install 13amp supply for a hot tub around 30m from the house.
Supply to property TN-C-S
Plan is to run a 4mm 2 core swa from a 16 amp mcb in the CU to a IP66 RCD switched fused spur (Aprox 25m from house)
Use the armour as the earth until it reaches the Rcd spur in which case I will heat shrink swa and then fit stuffing gland to terminate.
Earth rod with 10mm to the RCD spur and TT the rest.
Any advice would be great
Shirley how would you do that.Thanks for the dumb all I asked was how you would get the 10mm into the spur/FCU an answer would have been sufficient if its advice you want from me then forget it.
His name is Ant, Buzz, not Shirley.Shirley how would you do that.![]()
ok Shirley ant .His name is Ant, Buzz, not Shirley
That's what I asked the O.P.Shirley how would you do that.![]()
