S
Sparkoman85
Hi all.
New to the forum and I have absolutely no knowledge of electrics...
At the end of my garden I have a workshop and garage. I'm currently 'doing up the garage'.
The garage has it's own consumer unit which does the garage and the workshop. There were lots of wires trailing off behind the old walls but weren't connected to anything. I spoke to a few tradesmen at work and they suggested I turn off all the power and simply disconnect the wires that led to nothing. I got as far as disconnecting the one that was attached to the round junction box, but when I turned the power back on something blew and I had no power.
When I flipped the breaker switches back on, I had power in the workshop but not the garage. Then, when I turned on a plug in the workshop everything blew again.
Next morning I've come to have a look at it all.....everything works in the workshop except the plug that blew.
How did removing that wire effect everything?? Wondering if it's a simple fix before I call someone to have a look....
Sorry if I'm not being too clear, total noob at electrical stuff.
I've attached some pics.
Thanks in advance.
you said it ,do your self a favour get some body in so nobody gets heart attack .
Reactions: Deleted account
I've just tried all the plug sockets and they all work. But, fuses have blown in the plugs to my computer and computer speakers....
Don't mess with it yourself Mate, you need the services of an Electrician to sort that mess out, giving you advice other than switching the CU OFF would be wrong.
Yea I don't really want to be messing about with it. Even i can see that whoever did this originally made a right mess of it...
I think you’ll need to get someone in who knows what they are doing. It’s likely to be quite simple but needs to be worked through safely to establish what circuits you have and what is obsolete.
As above..... see if you can find a local Electrician to come sort it out.
He can also give you a heads up if anything needs upgrading while your 'doing it all up' :) ....
what they all say.i could fly over business class, but the cost would be horrendous. :rolleyes::rolleyes::rolleyes:
Very easy job for a local sparks , rip out the redundant stuff and then tidy up the rest.
Less than half a days work for an experience spark
Electrics problem....
Sparkoman85,
Dustydazzler,
