Admin
Staff member
Admin
Mod
Jun 28, 2007
14,781
65,798
Staffordshire
www.electriciansforums.net
Other
If other, please explain
Not an electrician at all.
Business Name
Ekthetikos
Just wondering which multifunctional testers you guys have, and how long have they lasted?
Hoping this becomes a handy thread for you all. There seems to be a massive price difference between them all. But then I guess some do things others don't? Not sure. :)
Let us know which multifunctional testers you have, which ones you wish you had, and how long the one you have has lasted so far. :D
Reactions: robd and seanpress
I have a Megger MFT 1741-BS. Had a Megger MFT 1553 before that. (Still have it as a backup.) New one is much faster and also has rechargeable batteries. Great instrument, although some would still swear by the 1500 series over the 1700 series.
  • Winner
Reactions: banny07 and Admin
Megger 1741, 1735, 1731 and a Metrel 3155 eurotest
  • Winner
Reactions: Admin
Metrel MI3000, lasted about 7 years from new but now has an intermittent fault on the navigation button, probably on the PCB.
Replaced with another preloved MI3000 whilst deciding on the next one.
Plus one for the Megger 1741, as has been said already. A top bit of kit. ??
1553. manufactured 2008. bought 2nd hand from a forum member 6 years ago. never missed a beat. still looks like new.
Reactions: MDJ and brucelee
Megger 3 piece since 2010 still fine.
Martindale ET4000 was great until it got nicked.
Reactions: Iona222
Fluke 1654 and a Metrel Easitest MI 2087, both bought used. The Fluke is a lot slicker but then it's newer and was more expensive. The Metrel is over 10 years old and still going strong.
Are we the only country to use MF testers ?
I have spoken to sparks from America , Canada , New Zealand , Australia , Greece and Spain non of which use a MF back home
Reactions: static zap
Old Robin KTS 1620 probably over 15 years old still works fine.....
and a 1970's wind up megger that still gives consistent readings.
Trusty old Dilog 9083P. Bought used from another spark who was upgrading. Very easy to use which makes it ideal for me. Worked well for 3 years and sails through its annual calibration.
Reactions: SparkySy
we used to use a big old wind up megger onboard ship for testing back in the late 90's.
I've had a metrel eurotest for about 15 years now without a glitch.
Also got a megger 1720 and kewtech, we had a megger 1730 until one of the lads dropped it, megger wanted £ 250.00 just to look at it , from what I've heard it's their standard reply. It's still sat in the office waiting for me to make a decision.
From what I gather we are. And from what I see here the americans dont even test their equivalent or an rcd. How do they even know it works??
Reactions: robd and DPG
Megger 1553. Keep thinking about 'upgrading' to the 1700 series but it still works fine! Had it around 11 years.
Fluke 1652 (been to repairers so so so many times)
DI log 9083P.........rubbish but used as back up for the Fluke as it was cheap and i needed a tester as Fluke being repaired again
Now got the Megger 1741
send it to The Calibration Centre, Stafford. a lot cheaper than Megger. failing which, i'll give you a tenner for it. o_Oo_Oo_O
Reactions: GMES
Fluke 1652, never missed a beat and passes calibration every time.
Reactions: Timbo
There is a company in Kemspton Bedforshire that are really good on repairing test equipment, they repaired my fluke even though parts were no longer sold by fluke etc etc
Reactions: PEG
Can our sponsor not sort you out they're Megger approved. www.test-meter.co.uk @Test-Meter I'm sure if you tell them you're admin they will try sort you out.
I use a Kewtech KT65DL mostly, had it for about 5 years? And a KT63 had a bit longer. Before that had a set of 3 Robin testers for quite a few years, preferred to use those but had to retire them as the loop tester is no good with RCBOs.
Cheeky plug: Multifunction Testers and Part P Test Equipment - https://www.test-meter.co.uk/multifunction-testers/
Thanks for the plug Dan - if anyone does want any info, we're always happy to help people find the right tester and we do have a fair few MFTs in stock to choose from!;)
We're always happy to provide a competitive, no obligation quote for repairs.
Just drop us a message on [email protected] or call 0113 248 9966 - ideally with a fault description - and we'll see what we can do!
Fluke 1654B. Never had any problems in 8 years. Last 2 years been calibrated at CEF calibration day for £20 + VAT.
  • Winner
Reactions: Admin and Jim_e_Jib
I've a Fluke MFT, but find on earth loop tests it's too sensitive to noise so I use it as a backup. I should really get around to selling it but it's hard to part with tools and equipment and one day it will be required.
My go to is a set of Megger separates. They never seem to miss a beat.
Kewtech KT65 for last 3 years. It’s been reliable and we understand each other. I do have Megger envy building, but the KT just won’t die :) .
Ha! Was in a very similar position until about a year ago, when I finally succumbed and got a Megger 1741. I still have fond memories of my KT63 (particularly when the Megger starts to weigh heavy round my neck!). The only thing I didn't like about the KT63 was it didn't remember the lead null reading after power-off... and if you didn't press a button for 3 minutes, it powered off. So, so irritating when you've got the wander lead out doing an R2 test, and it times out. I got used to impulsively pressing the test button every minute or so, a habit that took me several months to get out of with the Megger (which, of course, on a Megger, pressing the test button on continuity test removes the null reading!). I sold my KT63 on to a forum member. :)
Reactions: Wilko
Megger MFT 1730. Purchased in 2014.
I've got an Ethos kit from CEF. Obtained when previous employment company stopped trading. Does the job.
Separate continuity/insulation tester and loop/RCD tester.
Have used it since new in 2008. Goes through AA batteries like me and Greggs sausage rolls.
Will only buy a new kit or MFT when this one dies completely
  • Informative
I suspect you were very good at winding up Tel? ;):cool:
careful mate. we still have slave ships going from Liverpool to Louisiana. free passage. :p :p
Concur; Meggers standard charge is £280inc, or thats what I was charged. I did contact our forum sponsors, when my 1730 went wibble. But apparently if they can't fix it, it has to go back to Megger. I could not be without mine at the time for that extended period, so shipped it back to Megger. Does come back calibrated. Guess if you have other devices, thats not a consideration.
Perhaps Test Meter could comment on that.
Sounds good Tel. I could do with a cruise. Short hop from Louisiana to the Carribean. :p
you fancy a criuse? here's your ride.
Hi Midwest, I've just asked our repairs manager about this; we can fix most MFT issues in our calibration lab so it's very, very rare we would send them to Megger. (It would be something like needing new costly PCBs for us to do that.) All our repairs do also come back calibrated.
We're always happy to investigate and provide a no obligation quote or advise of other options moving forward.
Admin
Staff member
Admin
Mod
Staffordshire
Website
https://www.electriciansforums.net
Other
Business Name
Ekthetikos
Multifunctional Testers - Which one have you got and how long has it lasted?
Electrical Tools and Products
Admin,
Lister1987,
