Discuss AFDD in 18th 2nd Amendment in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I get it - you think the regs should be re-worded as you doubt the meaning of 'shall' and believe others are likely to find themselves in the same boat.After all this you still do not get it.
This may very well be the same personI mentioned a video that was recently posted in which one person had the same issue, but I'm sure it would be possible to find a YouTube video in which people struggle with the meaning of any word.
As does the English dictionaryThere has never been any doubt in my mind that the word "shall" means that it is not optional.
However, I am to some extent a product of the environment I was raised in, and this is the interpretation of "shall" that I was always exposed to. I do not rule out that others' experiences may differ to my own.
Languages are fluid and words and their meanings can change over time.
This is why it's good that the writers/editors of the wiring regulations see fit to include definitions that make clear the intended use of such important wordage.
Agreed. It's probably the oddest conversations I've found myself reading. And very polite responses from all.I must I remember that I shall never read through threads like this again!
A sensible post. The regs are a part of the building regulation which are law.I remember having a conversation 2 maybe 3 editions ago on a regs course and it came up that the regs had more of a legal leaning the way they had been written and the guy running the course said they had been written so the legal eagles had a better and clearer understanding of the regs when prosecuting someone who had breached the regs so maybe we should become lawyers so we can understand what we are supposed to be doing.
..or use firm words with no ambiguity.Languages are fluid and words and their meanings can change over time.
Please advise...what is a AFDD for?
Are you sure the question didn’t have a sarcastic intent?Arc fault detection. I would do an Internet search, there's loads of information about them.
Ambiguity only exists if one doesn't understand the meaning of words. This thread has firmly established the meaning of the word in question, highlighted that its meaning is clarified within the regs and how easily words can be defined by consulting a dictionary...or use firm words with no ambiguity.
I agree.Ambiguity only exists if one doesn't understand the meaning of words. This thread has firmly established the meaning of the word in question, highlighted that its meaning is clarified within the regs and how easily words can be defined by consulting a dictionary.
There's nothing left of this discussion to labour over and, as I've previously suggested, your objection would be better raised with the IET.
Wouldn't be the same fella, would it.This is one of those threads that will go on forever with little point. It reminds me of a couple of threads from a while ago, can't remember who they were started by though
It is not a novel to read while in bed.It’s a big book of regulations.
If I everything was “you must do this”, “you must do that”, “ you must not do the other” then it would be even more boring than it is now reading it cover to cover
“Shall” and “must” mean the same thing… you could interchange those two words in any of the regs and it would mean the same.
If its grammatically incorrect, then it wouldnt be in the regs at all.They aren't as interchangeable as you would think, swapping shall for must in the regulations would make them grammatically incorrect and potentially change their meaning.
What i meant was that as long as the sentence still made sense, then shall and must can be swapped.
I wouldn't say one is as "serious" as the other... even the ten commandments used "Shall" (which could be down to translation, of course)
I think ill just sit and watch some more python videos
Try a search for the CFGAR1-BDJust did a bit of digging as I know there have been changes to these boards over the years, but can not find anything which confirms if aluminium was ever used for the enclosure. I know they used to be (probably still are) cast, rather than pressed, which might account for the odd feel it had when drilling.
Not listed on the Bg site as far as I can see, but lots of other Sites, all saying aluminium.Try a search for the CFGAR1-BD
It may not put an end to the debate as it's now an obsolete part number.Not listed on the Bg site as far as I can see, but lots of other Sites, all saying aluminium.
If this is indeed the case, it should put an end to the debate of whether steel is effectively the only permissible material.
I wonder exactly when it became obsolete - prior to, or after, introduction of requirement for non- combustible material?
Still available though and 18th compliant.
Nuisance tripping? Where? How?I don't see an argument in favour of such distribution. It's likely that some sparks will take that sort of approach, but I'd expect most would follow a combination of logic, regulatory guidance and sound engineering judgment to limit the possibility of overloading and nuisance tripping.
Given the potential leakage from dish washers, washing machines and fridge freezers, not to mention a plethora of other appliances likely to make their way into modern homes, I'd question the ability of anyone designing such an installation.
It's not a case of 'we've always done it this way' - quite the opposite, in fact, and I don't consider the questions you're applying to such design to be sufficient to ensure a problem free installation for the modern home.Nuisance tripping? Where? How?
Q1? Is it safe? Yes.
Q2? Is it legal? Yes.
Q3? Does it protect against arcing? Yes.
You may not see an argument for it, and more will be on your side because of: we have alwasy done it this way. My point is that as AFDDs are expensive and mandatory with copper cable prices rising as world copper prices rise, these sorts of installations may be coming soon, and be quite common.
As a side issue, the British are famous for over-sizing cable. 6mm to a hob when 4mm will do it. 1.5mm for lighting when 1.00mm can do it, 2.5 from an FCU to an appliance when 1.5mm can do it, etc.
Tell me where that installation would give problems? All heavy appliance are on their own radial. As are the cooking appliances - a 3kW oven or hob with 13A plugs are not on the ring. The ring will take few heavy current appliances and these used only for very short periods. The installation will be sound indeed with high protection.ensure a problem free installation for the modern home.
Please explain how the regs allow this optimistic method of cable and protective device choiceA point brought up in this thread was that expensive AFDDs being mandatory in flats in blocks of 6 floors and over, installation will be cut to the bare bone to save costs, with 1940s/50s levels of scant circuits. They may filter down to all residential installations. But it can be done safely and cheaply...
So let's look at a 3 bed flat on the 6th floor.
1. One final ring with a 32A AFDD. This has no heavy current appliances apart from say a 3kW kettle. Most being TVs and the likes.
2. RCBOs on all other circuits.
3. LED lighting, smoke alarm and bathroom extractor fan has one circuit using 1.00mm cable. 3A RCBO.
4. Heavy kitchen appliances on one circuit. A 4mm cable to a bank of FCUs in the kitchen. 1.5mm cable from FCU to each appliance: w/machine, tumble dryer, dish washer. Appliances hard wired in - safer. 40A RCBO.
5. 6mm cooker cable to the oven and induction hob - no need to be on separate circuits. Both hard wired in. 40A RCBO.
So, four circuits. One AFDD and three RCBOs. 1.00mm and 1.5mm cable used. Cheap and safe.
The same could be for an average British semi. Maybe with two lighting circuits - but two are not required. This gives five circuits. Installation costs are then cut right down.
Q2 proves to some extent that this is trolling when did legal find it's way into an electrical installation when we all work to the recommendations of a non statutory documentNuisance tripping? Where? How?
Overloading? Where?
Q3? Does it protect against arcing on sockets? Yes.
Q4? Does it give full RCD protection? Yes.
Q5? Does full overload protection? Yes.
Q5? Does it give full fault protection? Yes.
Many years ago most installations only had 3 or 4 circuits so your argument isn't necessarily correct in general more circuits are used these days to minimise the inconvience of tripped circuit taking out a large section of the installationYou may not see an argument for it, and more will be on your side because of: we have alwasy done it this way. My point is that as AFDDs are expensive and mandatory with copper cable prices rising as world copper prices rise, these sorts of installations may be coming soon, and be quite common.
So where do you get that the British are famous for oversizing cable from and who is it thinks this could it be YOU when maybe it is done from a more cautious point of view at the design stage, electrical installations are always changing and evolving especially within the kitchen with hobs and ovens of various loads from 2Kw upto more than 10Kw a few extra pounds now can potentially save some money in the future when an appliance is changedAs a side issue, the British are famous for over-sizing cable. 6mm to a hob when 4mm will do it. 1.5mm for lighting when 1.00mm can do it, 2.5 from an FCU to an appliance when 1.5mm can do it, etc.
Oh I am feeding this troll. Apologies to all.At risk of feeding the troll
So where in this minimalist installation would you connect the outside lights, the garage, the shed in the garden, the EV chargepoint, the solar PV etc etc
With regard to nuisance tripping one RCBO trips and your cooking appliances are taken out could be a bit inconvienent on a Friday evening or a weekend or is it microwave dinners for a few days until the electrician calls to fix the fault
With regard to cable how many different cable sizes do you carry in stock or carry to site for the few metres of 1.5mm² from an FCU to an outlet plate needed on a job do you carry a drum of 1.5mm² for this or just use the 2.5mm² you have been using on this and other circuits
According to point 4 of your plan, all heavy loads are on a single radial and each appliance fed from a bank of FCUs.Tell me where that installation would give problems? All heavy appliance are on their own radial. As are the cooking appliances - a 3kW oven or hob with 13A plugs are not on the ring. The ring will take few heavy current appliances and these used only for very short periods. The installation will be sound indeed with high protection.
I think you may be on about devices that operate on earth leakage.
Table 4D5 might explain the issue a 4mm² cable on a 40A RCBO and 6mm² is pushing it"Please explain how the regs allow this optimistic method of cable and protective device choice"
Please explain where they do not?
What about a ground floor flat that has an exit to outside and not a communal area or a block of flats with open landings it is possible they may have outside lighting and one block of sheltered accomodation I was at recently had outdoor sockets on the open landings for charging the residents mobility chariots"So where in this minimalist installation would you connect the outside lights, the garage, the shed in the garden, the EV chargepoint, the solar PV etc etc"
None are required. It is a flat needing an AFDD. Sharpen up!
You are more than clearly demonstrating a level of ignorance regarding the standing of the regs here"when did legal find it's way into an electrical installation when we all work to the recommendations of a non statutory document"
The installation is legal and to 18th, inc amendments. That is clear.
I cannot find anything in the regs that suggests an installation that is compliant (a liitle clue regarding the previous comment) with the regs prevents nuisance tripping especially when you cannot control what is plugged into socket outlets"With regard to nuisance tripping"
That installation would not nuisance trip, as it is fitted to regs and tested.
So you highlight one type of circuit IMO there is little cost saving as when you have a fault you end up having to reconnect all the cables that break when you remove a switch to fault find"So where do you get that the British are famous for oversizing cable from"
You only have to look around. Even now, lighting using LEDs is done in 1.5mm in may installations.
That is good design. All heavy appliances are one circuit. It conforms to the 18th and its amendments.According to point 4 of your plan, all heavy loads are on a single radial and each appliance fed from a bank of FCUs.
If you consider that to be good design, and in accordance with regulatory requirements,
4mm cable can take at best around 41A. I meant to write 32A protecting the 4mm cable. A 3kW tumble dryer, washing machine 2.2kW and dishwasher at 1.5kW. All well under 32A when all full on. Depending on cost, it may be cheaper to replace the 4mm cable with a ring supplying the three heavy appliance FCUs.Table 4D5 might explain the issue a 4mm² cable on a 40A RCBO and 6mm² is pushing it
I said it was for a flat that needed AFDD. Sharpen up. Dishwasher (1.5kW), w/machine (2.2 kW), tumble dryer (3 KW), are all together under 32A, so fine on a radial. Fridge/freezer can go on the ring - they consume 150 watts, even the American style fridges it is only around 250 watts. They do not continuously run as the thermostats cut them out.Sure thing
If you wish to consider a combination of dish washer, fridge, freezer, washing machine, tumble dryer etc on one circuit to be good design, then I see no point in further discussion.
You have access to BS7671:2022 and if you believe the outlined installation (you also state is suitable for a semi-detached property, with the addition of an extra lighting circuit) is compliant, then that's your business and I'll leave you to it.
And this circuit will satisfy Regulation 531.3.2 (iii).4mm cable can take at best around 41A. I meant to write 32A protecting the 4mm cable. A 3kW tumble dryer, washing machine 2.2kW and dishwasher at 1.5kW. All well under 32A when all full on. DEpending on cost, it may be cheaper to replace the 4mm cable with a ring supply the three FCUs.
You have not a clue invenet all sort of future scearios. I am suprosed you [never mention wiring for a nuckear shelter in cae Putin sent over nukes. Read back on what I wrote. The design is all sound and to regs with ultmate protection inc AFDDs. Put 32A RCBO on the 4mm cable (my mistake).
Please tell me what regs book and table gives 4mm² T&E as able to carry at best 41A4mm cable can take at best around 41A. I meant to write 32A protecting the 4mm cable. A 3kW tumble dryer, washing machine 2.2kW and dishwasher at 1.5kW. All well under 32A when all full on. DEpending on cost, it may be cheaper to replace the 4mm cable with a ring supply the three FCUs.
I'm beginning to find your comments a bit condescending and very very stupid while you are trolling for a response and now you are backtracking because you are not even proof reading your replies before posting themYou have not a clue invenet all sort of future scearios. I am suprosed you [never mention wiring for a nuckear shelter in cae Putin sent over nukes. Read back on what I wrote. The design is all sound and to regs with ultmate protection inc AFDDs. Put 32A RCBO on the 4mm cable (my mistake).
Will you drop the sharpen up there is absolutely no need for it in a civilised conversation and it really makes you sound like a bullyI said it was for a flat that needed AFDD. Sharpen up. Dishwasher (1.5kW), w/machine (2.2 kW), tumble dryer (3 KW), are all together under 32A, so fine on a radial. Fridge/freezer can go on the ring - they consume 150 watts, even the American style fridges it is only around 250 watts. They do not continuously run as the thermostats cut them out.
The design I outlined, giving full protection to the 18th and amendments is 100% within regs. Sharpen up.
I feel like I am conversing with a confused apprentice still grappling with matters.
Yep. 32A RCBO with 4mm cable radial serving three FCUs. Show me where any reg say it is illegal?And this circuit will satisfy Regulation 531.3.2 (iii).
Regulation 531.3.2(iii) makes no reference to cable sizing so I can only assume you have no access to the 18th Ed.Yep. 32A RCBO with 4mm cable radial serving three FCUs. Show me where any reg say it is illegal?
You could have it on a 2.5mm ring, but there may be a danger of the 2.5mm on one of the legs of the ring being over loaded. So 4mm is 100% safe.
I find it amazing that two guys here cannot figure out a simple design and not even know it conform to the 18th and amendments.
It you stop being a contentious know-it-all not knowing too much, with a wandering mind, I may treat you differently. You think flats have garages and EV chargers. You have not much a clue.
I have to get you to think and read. Your minds is all over the place.Will you drop the sharpen up there is absolutely no need for it in a civilised conversation
Reply to AFDD in 18th 2nd Amendment in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
