Feb 1, 2024
exeter
Hello,
Just wondering, can two separate earth bars in a consumer unit be interconnected with a 10mm earth cable, or is it necessary to create an entirely new earth bond? Also, what are the pros and cons of each option? Many thanks in advance.
On Hager dual row consumer units, I've found the connection between the two earth bars (via the casing) not actually that good. So I always interconnect them, and I'd probably do the same here.
  • Informative
Reactions: Jim_e_Jib
They are already connected together through the steel enclosure.
But yes you can install a link between them if you want to.
Will do many thanks
I also connect the 2 bars to the side bolt on these, the coarse, rounded thread screws hager use can work loose. All those bushes and glands sat up on the cable protection lip are making me cringe. :openmouth:
exeter
Earth bars interconnected hager
lukest123,
freddo,
