Feb 21, 2025
Uk
If other, please explain
N/a
Business Name
N/a
Hiya,
Our neighbour runs an unarmoured cable on our land where I park my car, buried about an inch under the soil. This is used to power their garage and EV charger.
They have said that they have attempted to comply with BS7671 as it is in a green plastic pipe that looks like a hosepipe. We are still concerned about the safety, particularly as I drive my car over it and it it outside our back gate, so also accessible to the public. I'm not an electrician so getting a bit confused, but everything I'm reading about BS7671 leads me to believe that this should be an SWA cable and buried deeper underground. Can anyone give me advice please?
Image here :)
That does not comply to the regs,
Cables should be between 500/600cm
If vehicle are run over it then it can short out the cable, you should ask them
For some paper work to see if it complys
Running over you land.regding swa
Either clipped or buried.
Reactions: helpplease
Thanks Buzz! There's definitely no easements or wayleaves for them to have it on our land. When we raised our concerns about it being slightly buried, they actually recommended that we uncover it with it just lying on the grass, which definitely doesn't seem right to me as it's a big trip hazard!
It's dangerous, and they have no right to run anything on your land, I suggest you politely ask them to remove it, where to is not your problem, it does beg the question why have they run the cable on your property and not their own?
We have already asked them to make it safe or reroute it, we might have to ask them just to remove it at this point as they're ignoring us now!
looks like a DIY bodge job.
at the end of the day nobody has a right to run services across your land without your permission.
is there a route they could take that does not have to pass over your land?
Neighbours…. Everybody needs good neeeeeighbours 🎶🎵
I know what I’d like to do… but I wouldn’t trust them to have the correct protective device at the supply end.
Whether it’s done right or not, if they don’t have permission, then it has to come out, no question.
At least your driveway will never freeze over… I can see that getting very warm when it’s being used.
I know what I would do
Yes there are a couple of different options, hopefully they'll see sense before we have to escalate!
Hahaha, free outdoor heating, wonderful!
I think they believe if they just ignore us we'll forget about it and let them keep it there. Now I'm aware they weren't being honest about the safety of it, there's no chance!
I wish we'd done something more effective before speaking to them about it in the first place!
It's like being between a rock and a hard stone.you don't want to start a war with your neighbours but that to me is unacceptable, the cable has no protection ,May even not be rcd protected .I suppose if there ignoring you then you could phone your local council and voice your concerns .
Just park right on top of it and it’ll eventually pop what we protective device they’ve used.
I wonder what would happen if you had a bonfire close to or over the cable?
If your neighbours have installed a 7Kw chargepoint and only "attempted" to meet the requiremets of BS7671 with that shoddy install I doubt they would have made the neccessary ENA application and got the DNO approval to install it
Hiya,
Hiya,
Can you ask them where they get this green plastic hose pipe I've got a swa to run in for a shed but that looks like it might be a cheaper option .sorry im just funning with you if it wasn't electricity and we were talking about something else I'd put a spade through it .don't do that though lol
Why not put a spade through it
Not that I would condone damaging this illegal cable, but it may get caught on a rope tied on the back of your car and pulled out of the ground and the charge point and the consumer unit, now that would be inconvenient.
That actually happened on a job .they were digging up the drive with a mini diger and pulled a swa cable for outside lights and sockets .it almost ripped the consumer unit off the wall
I have seen the same digger driver pull up an SWA supply to a tower crane that he installed the day before.
Could always offer to re-route it for them, always nice to have a source of free electricity.
It certainly doesn't sound their attempt was anywhere good enough, certainly doesn't comply with BS7671 nor likely to get a Part P Compliance certificate issued, nor perhaps ENA/DNO approval #16 (not for the installation but unlikely to have been applied for!).
There is a joke in there to do with being Welsh and sheep, but I will resist. 🤣
Oi! We are not all like that. Only about 95% of us 😀
Actually if it wasn't for your wellies you've be in the hospital or infirmary.
Okay, how many understand that?
Reactions: DPG and helpplease
Thank you all for the great advice - and the laughs! This has been such a stressful situation so was in great need of both! :blush:
And they wonder why Welsh lamb tastes so good.
No, No, No, stop this please, the images in my head are driving me mad.
H
Electrician Talk
Deleted member 9648
Uk
N/a
Business Name
N/a
Does this meet BS 7671/ Part P? Advice needed please!
UK
helpplease,
Mike Johnson,
About us
  • Electricians Forums™ is a Recognised (unregistered) Trademark in the UK owned by Untold Media® which IS a Registered Trademark in the UK. We use the Trademark under licence and pay an annual fee of 250,000 GBP for it. Anybody found using the mark is liable to pay for the licence of it, and the legal costs, and court costs. We are aware of a Welsh company using the mark without permission and have activated Defensive Measure (legal route), and Offensive Measures (many that will damage their forum long-term) to take the website down via a number of routes, and to de-rank it in Google who are on our side in this case. CloudFlare is next, then XenForo who host it. Then Nominet. Then we should be able to take over the domain and shut the forum down.
Quick Navigation
User Menu
