Discuss Screwed over by builder - elecsa assessment - what do you reckon? in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
R
rocker
So I've been left right in the bloody mire by a thick bloody builder...... what a suprise!
Rewired a place a while ago.... was meant to be in before builder to 1st fix, builder comes in, then I come back and finish off. Builder messed about so it turned out i had to get my plasterer to low-fill the chases, and put in the second fix before the builder even turned up.
I've had one or two problems with the guy but just figured I'll go back in and do a bit of tidying up after he's finished (not too bothered as the house is my neighbours and a mate of mine)
Now, it's my annual re-assessment on Monday (or tomorrow, if you prefer). I didn't even want to use this house as I thought there'd be one or two issues from the builder, but unfortunately the job I was going to show has let me down, so I don't have much of an option.
Now this idiot has moved sockets etc which I knew about (posted on here a while ago), I went in and tested them, and told him not to touch any more electrical - if there was a problem, give me a ring. I go in and have a look now that he's finally finished..... the first thing I notice are downlights are the wrong colour. 'What's happened to them?' I ask the customer. 'Oh well the builder got me some LED bulbs but he said they wouldn't fit in your downlights (absolute rubbish) so he would better ones that would fit for free.' And what happened to the old ones? 'Oh, he took them'
So I have a shufty and lo-and-behold, he's nicked my fire rated chrome ones and put in standard white ones, not terminated particularly well either.
On to the kitchen, and again so that the guy can have LED GU10s, the builder's removed my enclosed ip rated dome and put in a rail with spots on it - no rating and in zones.
Also, he's put the sink in a different location than on the plans, and of course that puts my switches too close to it.
He also re-fixed all accessories at wonky angles after skimming, got them covered in PVA, then painted with them in situ, getting paint all over them (brushed steel and that, runied now).
So obviously I'm going to need to find this guy and have a quiet word.
HOWEVER my assessment is TOMORROW. I've tested as I would do on a board change, and everything is (suprisingly) OK, but I don't havwe the time to do anything else. I'm hoping I'll be able to explain to the guy, and ask him to just mark me as a 'board change', even though the job itself was a rewire, obviously it's no longer 'my' rewire. What do you lot think? Do you reckon he'll be OK with that, or do you think they are going to want a re visit. (to be honest, if they do I tink I may go Napit anyway)
I wouldn't have time anyway, but I don't want to rectify anything that's not 'dangerous' as I would like to have a bit of evidence as I may go down the court route (this guy has taken a massive amount of money off my neighbour for a pretty shoddy job)
I don't think this is unreasonable, but how do you lot see my chances? :mad:
Bad one rocker.
However you say zones for kitchen? Do you mean bathroom? If the spot rail is in the kitchen no problem.
IMO switches and sockets close to sink isn't covered by BS7671 and 300mm min distance is only a reccommendation, so shouldn't be too much of an issue, especially when you explain the builder changed from original plan.
Where are the downlights fitted and do they have to be fire rated? I don't think that the inspector will ask you to remove the fittings from ceiling anyway because it could damage the paint/ceiling, therefore how will he know if you've fitted fire hoods or not?
Anyway good luck with it.
bit of a nighmare there rocker. i would tell the builder if he touches anything on your jobs, you're going to report him to LABC and Trading Standards for interfering with electrical works for whivh he is not qualified to do.
Yea to be honest I wouldn't be quite so worried if it wasn't my assessment job on things like the switches, but I would like it to be top notch.
The downlights don't need to be fire rated, you're correct, but i usually use them, I used them on this job and even if it's not technically illegal, it still looks like bad form. Also, as the place is furnished I couldn't get to all of them to drop, and the customer understandably doesn't want the disruption - the one I managed to drop was not terminated that well.... sheath split and out of enclosure - I would mark it down on an inspaction, lets put it that way.
I know IEE isn't classing a kitchen as a special location any more, but ELECSA, as far as I'm aware, are, and so are my building control.
Anyway, regardless of this, I'm just looking for other peoples opinions on whether the guy is likely to be understanding and just look at what hasn't been messed with, i.e. the board. It's the same guy I had last year, and he's a nice chap actually, but I don't know if these guys are sort of forced to get a revisit whenever they can, if you know what I mean. I reckon NIC definitely would, but I'm hoping as elecsa tend to be a bit more understanding with the contractors that he will be OK with it.
To be honest, a board change is way above the threshold of what they will accept anyway....
do as you say and write eic for board earthing and bonding only, the inspector is not to know then sort out any complications later. chances are the inspector wouldnt be too concerned even if you told him
Got my assessment coming up so I know what it's like. You won't sleep tonight will you lol.
Anyway IMHO I don't think you've got too much to worry about.
Don't mention the poor terminations at downlights, I don't think he'll ask you to drop them.
If he says anything about the switches in kitchen blame builder, we can't be responsible for numptys coming in after us.
BS7671 makes no mention of zones in a kitchen even if it is a special location. Zones are measured from a shower basin (ie tray) or bath. You'd have to be rather small to be using a kitchen sink as a bath.
As for wonky accessories with muck all over them again just blame builder.
Don't get too stressed, have a glass of vino tonight and I'll be surprised if all isn't well tomorrow.
Especially if, as you say, he's a nice chap. Mostly I believe that they want to help us and not penalize us.
Good luck Rocker, let us know how it goes.
yeah all completely not your fault and the assessor will see that. as the others have said you should be fine, one thing though, don't fall out with the builder and if you do don't do work for him again, they can be a right nightmare at the best of times and will be worse if you fall out!! good luck for tomorrow hope all goes well
I would fully explain to the assessor what you have told us and the fact that you are now forced to make good all of the issues that the builder has bodged.
This could happen to any of us when we go back to job and someone has messed about moved tampered with electrical fittings. The house holder knows how you left it and has quite rightly told you that the builder has replaced your fittings. He can also look at the rest of the rewire which will show him the standard of your install.
In veiw of this I am sure the assesor will be easy on you and not subject you to a re visit costing £300 plus when it is not your fault at all.
Best of luck and hope all goes well.
Couldn't give a ---- about the builder to be honest - I wasn't subbing to him or anything, he was hired seperately and he was meant to be a mate of my mate's (the guy whose house it is) but has totally ripped him off for the quality of work that's been done. To be honest even if I could have gotten work out of him in the future (we never saw eye to eye from day one) then I certainly wouldn't want to work for him after he nicked my gear (presumably to use on another job and charge full whack, not that he's qualified or registered to be doing electrical work, of course)
yeah fair play, iv had it where builders do everything to make it hard for you, like tack both sides of a wall or tack the ceilings before you get your cables in, that sort of thing nothing a claw hammer doesnt fix though lol.
Hi Rocker i had my NICEIC inspection last week (23rd) and i always go back to the jobs that i plan to take him to, just to make sure everything is 100% but i asked him about this and i said would it be better if didnt and we could see what happens in the real world lol. so next year i am just going to take him back to jobs to see what we find as the NIC guy said to me the certificate is just a snapshot of how it was when you left it, what happen after that is nothing to do with you. i realy wouldnt worry and just explain you called in and the customer has told you what the builder has done. hope this helps
To support your "position" do you have any photo's taken before and after the changes?
Sounds like you're in a difficult position, good luck tomorrow.
Any jobs i ever do at the end of the day i go round and take pictures of everything, so i know its my work. If someone comes in after me i have proof that i didnt do the work or changes. and its back up incase i ever land up in court for somones elses shoddy work. I think if you had done that on this job then you would beable to argue your case better to the inspector. But i hope things turn out right for you. It ----es me off that other tradesmen dont care about any one else.
It is Alan yes - I've had him before and he is a cool guy, just hope he's cool enough lol. I'm always a gibbering wreck for a few days before my assessment though!
take it the builder's off your xmas list then
same here, make him plenty of tea and he'll be fine, i live on a farm and last time he came all he wanted to talk about is the chickens and veiws from my window.
Ha yep sounds like the same guy! I take it you're in Wales, then. The guy on the phone told me most of the time they try and swap assessors from year to year, but Alan has a bit of a monopoly on Wales lol
Hi Rocker, If what you say is true then report the builder right away...If in later years there is an insurance claim, YOU will be held liable as per building regs as being the nominated installer ie the electrical installer. He has removed highly spec fittings and replaced with low grade alternatives which was not on the agreed rewire.
2.1.2.1 Electrical
BS 7671 requires in Regulation 131.8 that no addition or alteration, temporary or permanent, shall be made to an existing installation, unless it has been ascertained that the rating and the condition of any existing equipment, including that of the supplier, which will have to carry any additional load is adequate for the altered circumstances and the earthing and bonding arrangements are also adequate.
When carrying out an addition or alteration to an existing electrical installation, the installer must confirm that the old installation meets the current requirements of the Building Regulations in so far as it affects the new installation and is adequate in all respects to supply the additional load if any; such that the new work is safe i.e. complies with Part 1 of BS 7671: Requirements for Electrical Installations.
In particular, the rating and the condition of the existing equipment belonging to both the customer and the electricity distributor can:
u carry the additional load, u provide adequate shock protection (fault loop impedances must be appropriate for the
protective devices), and u the earthing and equipotential bonding arrangements are satisfactory.
Defects in the existing installation affecting the alteration or addition must be made good. Defects in the electrical installation identified during the work and not affecting the addition or alteration must be identified in writing to the person ordering the work.
and
Additions or extensions to a building must comply with the Building Regulations. If wiring is carried out in an extension to an existing building, the wiring to the extension must comply not only with Part P but also with all the other appropriate requirements of the Building Regulations. There is no particular requirement to ensure compliance with the Building Regulations with respect to other parts of the building not affected by the extension, alteration or addition. The compliance with the Building Regulations of the existing building must not be degraded. For example energy efficient luminaires must not be replaced by less efficient luminaires however insistent the customer may be. Walls and ceilings must not be degraded by chases, drillings, etc.
Cheers sparks, I am going to be re-doing everything he's screwed up at some point so it will all be kosher again anyway. I do want to report this idiot, either that or give him a hiding lol, don't know which route to take though.
yeh mid wales (Builth wells)
alans been to me for the last few years
Yep all good! He couldn't believe the builder's antics! He wasn't bothered at all, though, was happy with the work. the only thing I did fall down on, which I'll clarify for everyone else, is calibration. I have a Seaward checkbox, and it says on elecsa's website that if you have calcard or your own checkbox you only need to calibrate every three years..... but that's the CHECKBOX not the tester. I thought it meant you don't need to ever calibrate the checkbox and if you use it monthly hen you only send your MFT in every three years instead of a year, but it's actually the checkbox whoch needs the calibration cert every three years!!!! Anyway, so I have to get that cal'd in 30 days, but that's it. Bang tidy.
Hi Rocker,
Just picked up this thread. Had similar experience with builder / plasterer before myself so know what you went through.
Glad the assessment went well. Nice one .
Cheers,
Lofty.
Reply to Screwed over by builder - elecsa assessment - what do you reckon? in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
We have had builders in, who have stopped for Xmas. My daughter tried to do a wash. The wash machine wouldnt. Its power socket is dead. I...
Hello, we moved in to a new build flat a couple of years ago and after a year or so we realised that the landlords electric meter had run up quite...
I was asked to see why a set of sockets weren’t working in the house (which appear to be a ring circuit based on breakers) There was no power on...
This is a strange one, my neighbour is a bit mad, he had a largish extension built in about 2015, the builder attempted to do everything including...
