Discuss Down lights install to lighting with no earth in the Australia area at ElectriciansForums.net
I dont see the problem really, stick in a cpc regardless. Because A: anything happens or they want something changing most of the time you will be first one back. B: i know guys on here will follow the regs by the book but regs do change and chances are at some point it will be necessary anyway. C: i hate following up jobs where bad sparks over the years will just leave the odd thing here and there and we end up with all the bad habits of past sparkys to sort out. just do it now tell the customer that you strongly recommend it.
I think the idea of getting an earth would mean running it from MET which if the case you might as well run in seperate T&E from dist' board he originally asked his question because i assume this isnt an viable option or affordable but yes agree, i had same situe recently and ran new lighting circuit to kitchen and disregarded the existing with no earth just making the customer aware of the safety issues.
Reply to Down lights install to lighting with no earth in the Australia area at ElectriciansForums.net
Hi all. Reasonably competant non electrical engineer homeowner here. I have a question for the experts: I recently replaced a horrible...
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
I am installing 9 LED downlights each with an RGB bulb in (i will try attach pictures on them) - anyway I have been told that they need to be...
